Hi all,
I have run into a strange problem with my M4000P which I have been as yet unable to solve... "hoping" someone else has seen this issue and can help.
I transferred some files to the hard disk the other as I have done hundreds of time before, and did nothing out of the ordinary. When I tried to play the files (standard divx .avi), an error pops up saying that the file is unsupported. I dismiss the error message, and try to replay it again immediately, and the file plays without issues.
This happens with every avi I have on the box
I use the icon.tvix file to show folder pictures of the DVDs that I have stored on the box, and at the same time as the above issue I have noticed that when I navigate through the folders, initially the folder icons do not pop up. When I go into the folders, then back out of them, the folders suddenly appear.... I hope I am explaing this well enough!...
So, I have tried a few things to resolve it... but nothing has worked so far...
- The 500GB drive was pretty full (about 80 Gig left) so I removed some stuff
- I removed the files that I had just put on the box
- I have scanned for viruses, and performed an error check (which took hours!)
- I have downgraded the OS version to 2.2.5 and 2.2.0 from 2.2.7 which is the latest, and change the regional software version from PAL to NTSC.
- I have changed settings in the OS for the viewing options
All of these are to no avail.... Please help!
) but luckily I just about managed it. Am now in the process of buying a new server to store all data and samba share it from there as required.
