AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Can't Connect Wii to Sony STR-DG820
post #1 of 5
Just got a Wii, tried to hook it up to the Sony STR-DG820, but getting no picture. I have a cable box and blu-ray hooked up via HDMI and an HDMI out to the TV... those things work fine, but when I connect the Wii to VIDEO 1, no picture and no sound either through analog audio inputs. BTW, I did hook it up directly to the TV and it worked fine, anyone know what I'm doing wrong?
post #2 of 5
Just curious, are you sure you put the cables in the Video 1 "INPUTS", opposed to OUTPUTS?
post #3 of 5
Yes, for sure. I think after doing some research I found the 820 won't pass component video through the HDMI to the TV... does anyone know if this is true? And if so, is there a workaround?
post #4 of 5
Connect component cables from the receiver to the tv (as well as hdmi) - you will have to switch the input on the receiver and the tv though. That is what I had to do with my pioneer receiver, since it doesn't pass analog to hdmi either.
post #5 of 5
Thanks for the suggestion, but that won't work for our setup. The LCD is wall mounted with HDMI and power hidden behind drywall, only thing I can access easily is the yellow/red/white cables on the side. I'll just unplug those when no one is playing Wii.
