I could really use some help and knowlodge if anyone could possible let me know the answer to my quesion. I have read the manual cover to cover more times that I would like to think and can not find the answer to this quesion. I am trying to make sure all of my audio settings on my receiver (Denon AVR 3300) and blu-ray player, Samsung BD-P1400 are correct so that I am getting the new lossless audio codecs. My main question is this. Can someone tell me if the Denon AVR 3300 has a PCM down sampling rate of 48Khz or 96Khz? By the way I have my audio going from the Samsung via the 5.1 analog outs to the Denon analog ins (Denon has no HDMI, older receiver) and have audio set to PCM on the Samsung, is this correct? Thank you very much for your help and advice
AVS › AVS Forum › Audio › Receivers, Amps, and Processors › I Know, another connection question, but I could really use the help guys.
AVS Top Picks
Since you're using the analog output from your blu-ray it doesn't matter how your receiver processes a digital signal.Same thing goes for the PCM setting of your Sammy.Just sit back and enjoy!
