Originally Posted by B_Bear
Thanks MVP.
My listening is almost exclusively movies/TV; very little MC audio. The couch where I listen is parallel to the back wall that's ~2 feet away. I currently have mounted on the rear wall two rear channel speakers (direct firing) and one surround back (direct firing) all aimed toward the listening positions at the couch. I don't have the option of mounting any speakers on the side walls or to the ceiling.
Any thoughts about whether I would benefit by going with bipolar Gem XLs for the rear channels (not the surround back) give my listening arrangement?
Thanks in advance.
Thanks MVP.
Thanks in advance.
Hey, B_Bear:
I'd be interested in what everyone else has to say, but IMHO, I think in your setting (where the surrounds are fairly close to the couch), the bipolar Gem XL's would likely help make your surrounds less localizable. Whether you just replace the 2 rear surrounds, or the EX channel as well would be up to you--although I think traditionally, the EX was supposed to be a direct radiator since it's the rear center channel (someone please correct me if I'm wrong).
As is often suggested on AVS, it would be helpful to acquire the Gem's locally so that you can audition them to make a truly informed choice.
A couple other thoughts--you've probably done this already, but you will probably want to mount those surrounds pretty high up (while still pointing at the listening position). A final consideration might be: which speakers (the Gem's or the Sixes) match the timbre of your fronts/center the best in your particular setup.
Good luck, and please let us know how it goes!
I guess it's like that for all of us, though. I think I've finally finished... for the next year or so at least. Eventually, someone will tempt me with a "must have" upgrade
, but for now...
