AVS › AVS Forum › Audio › Speakers › Definitive Technology Mythos Series Thread
Definitive Technology Mythos Series Thread - Page 68
post #2011 of 5218
I emailed Def Tech about mounting Gem XL's on the Gem stands and here is the reply I got. (very quick response I might add)
Rick,
Thanks for your recent email to Definitive Technology. First, we do not manufacture stands for the Gem XLs. (Sorry.)
Next, technically (or legally) the Mythos Gem XLs used with our GemStands would not be stable enough to pass the government's "tip test"...So I could not recommend using the Mythos Gem XLs with our Mythos GemStands.
Off the record, (and assuming the speakers would be placed in a location where they're not likely to be bumped into), the Mythos Gem XLs would work on the GemStands - and look "okay". (Please refer to the attached photos.)
If you need any other information, please email me at chet.pelkowski@definitivetech.com.
Chet Pelkowski
PS. An "aftermarket" stand from Omnimount called the Gemini 1 would work well with the Gem XLs. You can find more information on this stand at:
http://www.omnimount.com/Product/Spe...es/Gemini%201/
Here are the pics
By ric2l at 2009-12-15
post #2012 of 5218
Originally Posted by fquails View Post
I would suggest the PB12-nsd (box) for a couple of reasons:
1. You have the space for it, and I think it'll look much better with your setup. All you have to do is put it where you had your old sub as shown in your pics.
2. The charts at svsound.com appear to indicate that the box (PB12) has a flatter frequency response from slightly under 20hz all the way up to around 80hz (where you will probably set the crossover for your Mythos Ones). If you plan to have just one subwoofer, I would suggest you go with the PB12 for a flatter response from the low to mid bass frequencies. I've also read that its flatter mid-bass response makes it sound much crisper and better for music.
I have the cylinder (PC12), and in my room, the sub's sound is noticeably more pronounced/heavy at the lower frequencies, and has a dropoff in output at around 60Hz to 80Hz, so the sound is somewhat 'bloated'. This appears to be consistent with the PC12-NSD's chart shown at svsound.com where mid-bass output is shown to be about 3-5dB less than the low end bass. However, this is a non-issue for me because I use the PC12-NSD only for frequencies 40Hz and under. I have another sub for 40Hz-80Hz. That, and the fact that the only space I have for a second sub requires a small footprint, and the cylinder is the perfect fit.
If I had the space, and can have only one sub, I would likely have purchased the PB12-NSD instead of the cylinder for the flatter mid-bass frequency response.
Hey Fquails and MVP, thank you for your opinions and response.
Well, guys, I'm loving my Mythos 1 and Mythos 9 setup a month in. Taking the SCII i bought a few weeks back tomorrow to Magnolia.
I narrowed my subwoofer search to the the PB12-NSD recommended by Fquails and the MFW-15; I mentioned in a previous post that the MFW might not be for me because of previous issues it had but I reconsidered after reading the Craigsub list. Well, that and after I spoke to a sales person at SVS (Doug) he told me I should go for the PB/PC Plus if I want to, 'FEEL' the bass in my room. As opposed to the regular PB12-NSD as it would be an uprgrade over the SCII but I won't get to feel the bass - what I'm looking for. Being that the Plus is out of my price range I saw the MFW-15 has almost as good performance as the PB Ultra - Wow, I say.
So today, I spoke to a gentleman named Mark at AV123 and I purchased (ordered) a MFW-15 subwoofer. Got a good deal, $629 shipped for a new black sub to be delivered in January.
Taking a leap of faith here as I'm hoping I get a sub without any issues and hope it blends in well with the Mythos 1's.
Again, I only placed the order and it is not to be delivered until late next month. As auditioning these subs is not an option for me, I take the opinions and advice from you Gentlemen in making an educated decision. Should I go for a sure thing, the SVS or go for something a little louder but MIGHT have problems?
If anyone thinks the PB12-NSD is still a better option, Please, PLEASE let me know
Thank you all in advance as your opinions are highly regarded.
Michael
post #2013 of 5218
Originally Posted by cdnbum88 View Post
Anyone have a Supercube I and can provide your setup settings? Just wanted a benchmark on what to do before and/or after I run Audyessy.
Are looking strictly for crossover settings?
post #2014 of 5218
Michael
There are quite a number of Mythos 1 owners with one or two MFW-15 sub(s). They seem to love it, and have had no troubles.
Later on down the road, as time and budget permits, you may want to consider EQ'ing your sub as it will make a night and day difference in blending the sub with the Mythos Ones (in my room, anyway). EQing options include the BFD 1124P (cheap but lots of work and learning curve) Velodyne SMS-1 (expensive but easy to use and quick)
post #2015 of 5218
Michael
I'm running the M1s all around with an M8 with the MFW-15 and am extremely happy with my decision! I was deciding between the PC-12 Plus (which I got to hear) and the MFW-15 (without having tested it) and definitely feel the MFW-15 is a more capable sub as long as there are no manufacturing issues with it.
I ran some test tones last night and at about 1/3rd gain and -25db, I was shaking my apartment with clean bass except for a peak at 60hz (dish rattling). It got down to the low 20hz but I'll need to move it around to get a solid response at 20hz and clean it up at 60hz. Because I'm in an apartment with a smallish living room I don't have as much freedom with the placement.
post #2016 of 5218
My sub seems to be on a sub-par performance. I have a 3 year old velodyne 1200 with my mythos ones front and rear. sc-05, 24x16 room. It seems that its struggling. I've set all speakers correctly. Bass seems lacking. I'm going to play around a little more, recheck settings. Any input would be helpful.
Screener
post #2017 of 5218
I narrowed my subwoofer search to the the PB12-NSD recommended by Fquails and the MFW-15. . .So today, I spoke to a gentleman named Mark at AV123 and I purchased (ordered) a MFW-15 subwoofer. Got a good deal, $629 shipped for a new black sub to be delivered in January. . .Should I go for a sure thing, the SVS or go for something a little louder but MIGHT have problems. . .Michael
I think you'll be fine with the MFW-15 (just check it over carefully for any defects). Great performing sub--almost bought 2 myself but ended up with 2 SVS instead. (darn those persuasive SVS guys!) (Addendum: Just did some reading up on several AV Forum folks' problems with the maker of the MFW (av123)--before buying one of these subs, I'd recommend researching their comments).
. . .Later on down the road, as time and budget permits, you may want to consider EQ'ing your sub as it will make a night and day difference in blending the sub with the Mythos Ones (in my room, anyway). EQing options include the BFD 1124P (cheap but lots of work and learning curve), Velodyne SMS-1(expensive but easy to use and quick)
Actually, The SMS-1 is not so expensive anymore--they are going for around half retail from authorized dealers if you shop around (even less on ebay). Mine just arrived, and I can't wait to unleash it on my subs to see what happens.
Also, the SVS AS-EQ1 is a powerful unit with Audyssey techonology that handles multiple subs (although it is rather expensive still).
post #2018 of 5218
I have an unopened Gem Stand if anyone is interested. I will sell CHEAP!
post #2019 of 5218
You know, not sure what I need.
Thinking what would you set before you run Audyssey and is there anything you do after you run it if you are happy with the calibrate sound?
I have printed out the Audyssey setup guide and will follow that, but wanted SC1 folks opinions or recommendations.
post #2020 of 5218
I would be interested but they are not expandable correct? Based on the dimensions I see and the height of my couch and where mine are placed currently they would be barely over the top of the couch
post #2021 of 5218
I am 99% sure they are not but dont really want to open them up. I know that most people prefer to buy unopened boxes. Check with Definitive tech support. They are extremely knowledgable and responsive.
post #2022 of 5218
I think its worth mentioning Audyssey will set the sub much further away than what it really is. Do not be alarmed. Its actually correct. It's based on the quickness of the response. Others here have commented in this thread about it and are better suited to elaborate. Also, it will set the decibel output much lower compared to your other speakers to try and correctly match the sound.
Other than that, I'm happy with the Audyssey settings, however I have slightly tweaked some of the speaker output decibels based on my personal preferences. It also seems to work best if you have more of central seating location rather than all over room. Just my opinion.
post #2023 of 5218
The SMS-1 is an amazing tool. I think the price can be much lower if they apply some value engineering for the product. The mike, mike stand, the case and other parts/accessories are way over-built IMHO. Much too nice for parts that will be used maybe once, minimally at best. It's like killing bugs using a Stinger missile, when a simple fly swatter will do.
post #2024 of 5218
Well put. What's even a worse value is Velodyne's signal averaging kit (an accessory kit that allows you to hook up 5 mics to the SMS-1, thus giving you a 5 seat position averaged signal). For the price of that accessory, I could just buy another sub and be done with it!
post #2025 of 5218
Michael
I just got my second SVS PB12NSD sub about two weeks ago. At first, my wife was very skeptical (I know, oxymoron) about needing a second sub after getting the ST's, 10 center speaker and our first PB12 not too long ago. Christmas, bills, kids, where are you going to put that "thing" stuff (Hi Honey). Then last night we watched the latest Rambo movie recorded from our DVR, just DD 5.2, the part when the old unexploded WWII bomb gets exploded by Rambo. Huge, deep, low bass effect. Incredibly she looks across the sofa, eyes wide open and says "Wow that's sooo much better now!" Then after the movie she says "OK, the second sub is worth it". Now, if anybody knows my wife that's saying something. To me the bass is now even, symmetrical and full and most impressively, earthshaking. The PB12NSD is very good at movie sub effects, imo. The ST's and the 10 center are equally impressive, I am finding a whole new appreciation for music and movies. A very happy owner. Just passing my thoughts for what they are worth, good luck.
post #2026 of 5218
Hey guys, Just wanted to thank everyone of you in here on this thread. After going through all the 68 pages and some more on other threads, i took the plunge and brought Mythos ST x 2 for front, Gem XL's for the rear, 10 Center surround.
Please guide me on a good receiver which will work good with this package.
I am sure that the superior sound of Def Tech Mythos can be used perfectly with a compatible receiever which can use the real potential of the speaker.
Budget = 1000 dollars.
Help appreciated.
post #2027 of 5218
Help appreciated.
Congrats! You've got the makings of a sweet system.
One of the mid range Pioneer Elite receivers would fit the bill nicely at that price point.
I also favor the Yamaha receivers, but I'm in the minority here
post #2028 of 5218
Great story. It's always awesome when the WAF goes through the roof once you finally get the boxes hooked up!
post #2029 of 5218
Thanks for your suggestion, i read somewhere that pioneer has good budget receivers for the thx line. Also their frequency is better than denon and onkyo?
You have any specific make/model of Pioneers Elite?
post #2030 of 5218
With the speaker package you purchased I see the Pioneer Elite SC-25 or SC-27. I see no other model that would make them sing the way they do. I have mine paired with a SC-07 which is last years model.
post #2031 of 5218
Hey guys I am kind of a newbie here. I was just wondering if you guys have pictures of you HT setps on this site like blu ray.com and if so where would I navigate. I have my pics posted of my 7.2 def tech setup on that site wich consists of a denon 4308ci, 4 Mythos STS's 1 Mythos Ten, 2 Mythos Gem XL's and 2 Supercube Reference Subwoofers. but I would like to see more Def Tech set ups!
post #2032 of 5218
Help appreciated.
Nice. I think your are going to be very happy with this once you get it set up to your liking. My setup required a bit of seat time, even with the help of my brother in law, to set the toe angle and positioning right. The time was well spent. I am happy with my Marantz SR6003 and I have heard good things about the 6004, but I am sure there are many other good AVR's as well in that price range (Denon, Yamaha, Pioneer were also on my list). Congrats.
post #2033 of 5218
See the first post in this thread for links to people's setups.
(BTW, I'm always looking for more pics, people! )
post #2034 of 5218
What makes the Pioneers such a good match for the Mythos line is that they tend to have a very warm, laid back sound--yet with plenty of punch. This compliments the tendency towards brightness that some claim the Mythos line is prone to. IMHO, that's what separates out the Pioneer Elites from the rest. (I second the notion of the SC-25 and SC-27. If you could find an SC-05 or SC-07 leftover from last year, they would be great too).
I own an Pioneer Elite receiver in my upstairs theater, but in my main theater, I've fallen for the Yamaha Z7. It has a more forward sound than the Pioneers, but the dynamic range is pretty awesome, and it has some useful features, the Pioneer's lack (HDMI passthrough, some cool DSP modes, etc.). The amp is an amazing beast as well--haven't been able to overdrive this with any material I've come accross. Wham!
Bottom line: you were smart and put your money in the most important part of the equipment group.** Wherever you go from here--it's going to be hard to mess this up.
Good luck!
**PS: don't forget, though, the most important part of a home theater is the room itself--don't skimp on getting that right.
post #2035 of 5218
Wow thank you so much friends. I have truly gained a wealth of information from this forum, which helped me buy the right product. After a thorough survey from this site and from help from members of this forum a month back i brought Samsung 52" LCD make LN52B750.. and did the same for the Home Theater audio setup. Got a lot of help from you guys. And i am truly thankful to you all.
I will settle with Pioneer Elite SC-27 as guided by mvp2005fan and Mantis10, i did some research on the AVR, and they've got rave reviews guys... u were spot on.
After the receivers my next target is to get a good subwoofer. As of now, i am strapped out of budget.. hence i will be buying this next month or so.
My initial research has lead me to SVS or Epik series subwoofers.
Any suggestion on this mates?
Also wanted to know, what other add-on's/accessories i need to buy to set these up?? Do i need to get some premuium speaker cables.. etc?? What are the other things i will need on the finer side?
@mvpfan2005... you are true abt the room and setting the speakers accordingly. I have ample time during christmas vacations off from my work.
Anyone from Chicago downtown.. who has the same setup.. and can guide me for proper adjustments/positioning for these speakers, wud really appreciate help on this.
thanks all again friends
post #2036 of 5218
Has anyone here mounted their Mythos in an "in-wall" configuration with good results, is there any good reason not to do this?
My front stud wall where my acoustically transparent screen will go does not have drywall on it yet and I could add another row of studs giving me an 8" wall depth, is this a bad idea?" I would like to mount my screen directly to the wall with the front speakers behind the screen.
Thank you.
post #2037 of 5218
Thank you.
As you know, the Mythos line is not meant to be put in an enclosure--doing so would almost certainly alter the sound (which may be good or bad, depending on your preferences).
If I really wanted the Def Tech sound but was limited to in-wall, I'd go with the higher end Def Tech Ultimate In-Wall speakers. They use the same drivers as many of the Mythos speakers and are built like tanks. I use a pair of Ultimate In-Wall surrounds as my side surrounds in the ceiling in my Mythos based system, and I can tell you that sonically, they carry the same voice (and sound pretty amazing--when I first installed them, I played some stereo just through them, and was surprised how good they sounded).
They are also really easy to mount in-wall, although ceiling mounting requires careful planning and ceiling joists that run the right direction (they are so heavy they need to be screwed into the joists.
In any event, I think that while the Mythos may work in-wall, the UIW are designed for that purpose and really deliver the goods.
post #2038 of 5218
If you search on "subwoofer" in this thread, you'll get lots of recommendations. Just about any quality sub will match your system well, as long as you set things up correctly. A lot of folks (including myself) like the IO dealers: SVS, MFW, Epik, etc. It boils down to available placement space, desired power and range, asthetics, and budget. My only suggestion is, if you are planning to add a sub to an ST system, make sure it's a sub that will actually add something to your system (i.e. plays really low and loud), as the ST's certainly can hold their own without a sub. In fact, you might just wait and see how you like the ST's alone before investing in a sub right away.
In terms of "add/ons", I would budget for the following (in no particular order): good quality surge suppressor and/or UPS; room treatments (bass traps,etc.) , sound pressure level meter, universal remote (I like Harmony One), HDTV source (FIOS, cable, satellite), Blu-ray player (Hard to beat the Oppo-83), Ideal-Lume, and professional calibration of your television and sound system.
The one thing I wouldn't spend crazy money on are speaker cables. Most folks here like Monoprice or Blue Jeans Cable.
Just my opinions--would be interested in what others have to say--lot of wisdom in this group of folks on this thread!
post #2039 of 5218
Yeah, you can get 5 pairs of banana plugs and 100ft of 14AWG speaker cable from Monoprice for about $30. That's what I did and it works great for me.
post #2040 of 5218
I'm considering Mythos 10's for my front three speakers with a 140" wide screen.
I will need to toe the side 10's in 30 or more degrees and would like to be able to adjust the angle of the horizontal 10 center channel speaker too.
Is there a way to rig the 10's mounting brackets to allow for these adjustments?
Thank you.
  Back to Forum: Speakers
