Originally Posted by Big Picture
I'm considering Mythos 10's for my front three speakers with a 140" wide screen.
I will need to toe the side 10's in 30 or more degrees and would like to be able to adjust the angle of the horizontal 10 center channel speaker too.
Is there a way to rig the 10's mounting brackets to allow for these adjustments?
Thank you.
Thank you.
I am considering Mythos ine's for my fronts and had the same question. I asked DefTech and this is what I was told:
"Ultimately, the dispersion pattern of the Mythos speakers is a bit wider than most other speakers. You wouldn't normally need to angle or toe these speakers inward."
I figured if and when I get them and I still need to angle them I would attach a piece of wood the same dimensions as the wall mount and maybe some shims at the edges to angle them in as I attach the wall mount to the wood. Or maybe I would do something with small hinges. You'll have to experiment and see what you can come up with I guess.
