AVS › AVS Forum › Audio › Speakers › Definitive Technology Mythos Series Thread
Definitive Technology Mythos Series Thread - Page 82
post #2431 of 5215
Originally Posted by fuwa View Post
Hi.
I just purchased some Def Tech ST floor demos from BB.
There are two issues. When there is a low bass sound such as the thunder at the end of Michael Jackson's Jam, there is a slight vibrating of the speaker grill. It is not as bad as before because Def Tech sent me the missing rubber hold cup for the grill prong. Is this normal or to be expected after some use?
The other issue is that when I connect the speakers LFE input and use the Pioneer 23 receiver test tone, I can hear a slight static noise when the tone goes to the sub. This does not occur when I use the Martin Logan Dymamo sub. I took the speaker back to BB and we tried the tone using another receiver and the noise was not as evident. Surprisingly when we tried a new STS there was a crackling poping noise which was much worse.
The BB speaker installer didn't think the noise was out of the normal and suggested sending the L and R pre-amp outs to the LFE of the ST and the subout from the Pioneer to the Martin Logan sub. This seems to work fine.
My question is has anyone else noticed a slight noise when running the test tone from a Pioneer receiver throught the ST sub? Is this something I should be concerned about?
1) This is not normal. I have Installed many pairs of Mythos towers with no problems. Now breaking the grill pins is another story, they seem flimsy and they break very easy. I suggested to DT to go all magnetic.
2) You should not have any static type sound. Check or replace your interconnects and Y splitter. I'm assuming there is a problem there.
As far as using line level out of the L R for the towers , thats just silly. Run speaker wire there and use your ML sub for LFE. You do however have to tune the internal subs so they sound correct for music.
If you need help with that just ask. I have a technic that works great.
post #2432 of 5215
Originally Posted by fquails View Post
Anyone here use the spikes that came with your Mythos speakers? Does it make a difference in SQ? I've been using the rubber feet on tile floor (room treated with rugs, curtains, etc.).
I use spikes with my fronts--don't think if affects the sound quality in an audible way for me. Does make them harder to move or knock over with minor trauma.
post #2433 of 5215
Could we get links to Mantis10's techniques added to the first post please. It's very useful information.
post #2434 of 5215
Done. Thanks for the suggestion (and to Mantis10 for posting the tips)
post #2435 of 5215
The grill pins are OK. The vibration is slight. I am concerned about the extraneous noise; kind of like the humming of an aircraft rotar blade. This is at all volume levels and only occurs at very deep bass such as the test tone; it is not overwhelming, but it is there. I tried the ML sub with the same connections and there was no extraneous noise.
When we tried the test tone from a different receiver at BB, the extraneous noise was not as noticeable but strangely when a new STS was connected there was a popping noise every 5-10 seconds.
When you installed the Mythos Towers did you test the speaker levels with the test tone? When I played the STs at BB using the wire only connections and just music and movies they sounded fine; it wasn't until I got home and used the level test tone that I noticed the extraneous noise.
I am now using the LFE output from the receiver to the ML sub. For the LFE inputs on the ST I am using the receiver preouts in addition to the standard wire connections.
These speakers are demos so I am wondering if they may have been misused at BB. I had to call Def Tech to replace 5 missing rubber hold cups for the grills and it appears that someone did get into the sub section as one of the screws shows wear.
I am at the point of returning all this and going with the Mirage OMD-15 system that is on sale for 60% brand new. I tried the Mirage OS3 system and I liked them but I wanted to go with the more room filling sound of the STs. Do you have any opinions on the Mirage OMD-15 system?
I appreciate your input as you appear to be very knowledgeable concerning these speakers.
post #2436 of 5215
Hi all,
I read almost all of this thread (took forever) and wanted to confirm/get opinions on one issue.
I ordered a pair of Mythos 2's off Amazon for the great price. I was looking at a Mythos 3 as a center, however, reading everything says the 2s and 3 are essentially the same speaker. Is there a reason to buy a 3 vs buying another 2 and using it horizontally as a center speaker?
I'm leaning towards getting another 2, but wanted to check.
post #2437 of 5215
Hi,
I'm looking to get some advice about my current HT set-up. I recently purchased the following from BB Magnolia and had it installed a couple of weeks ago: Procenter 1000, Promonitor 800 (2), and Mythos Gem (2). I have the Mythos Gems as my FL + FR, PM 800's as my RR + RL, PC1000 as my center. Sub duty is Velodyne ULD-12. Everything is powered by My Denon AVR-3801 (probably will upgrade to something that has HDMI in/out to take advantage of new audio codec's from Blu-ray). Would I benefit from swapping the Mythos Gem's and the PM 800's in position? Or would it be better to get a mythos Center channel to match the gem's? Any other suggestions? I appreciate your help.
Nathan
post #2438 of 5215
Originally Posted by Kjiwani View Post
Hi all,
I'd get whatever is cheaper. There's no reason to spend extra on a 3 just because it has a different mount on the back.
post #2439 of 5215
Many people get confused on how to use the ST or STS speakers. I will lay down a guide which all can follow to the letter for maximum results.
So lets get stared .
Home theater use , if there is no external sub in the system , run speaker wire and LFE to each tower speaker. Set your preamp/ receiver to large fronts and yes to sub. This will allow the internal subs to play the LFE direct from line level and allow the front channels be full range. You have to tune the speaker first without having LFE there , then you use the LFE line level control to tailor there output.
Steps to calibrate the ST or STS speaker before LFE.
1. Turn rear volume up to 12 oclock.
2. Use a SPL meter and meter the speaker at the listening area to 75db.
3. Turn sub level up until the DB goes above 75db then back it down to get 75db.
What you just did is "tune" the ST or STS for full range use. This will make the speaker appear to be full range passive sounding for 2 channel playback.
Adding in LFE.
1. Install Line Level LFE to each Tower.
2. Use a Y splitter RCA if your receiver or preamp does not have dual Sub outs.
3.Manually calibrate speakers with SPL and adjust line level LFE to 75db with all other speakers in system.
This now will give you the best of both worlds.
So this is a great guide line to follow when owning these speakers. You can set them up any way you like. I have Installed these speakers many times and I personally own them myself. This is what I found to work the best. I learned from Def Tech engineers how they are designed and what makes them work. I took that info and used it then added in my personal touch from experience.
Just getting around to reading this. This is good stuff. What are the steps if you do have an external sub in the mix for HT use?
BTW anyone combine these speakers with a Seaton Submersive? Saving my pennies to get one.
post #2440 of 5215
I contacted Chet from Def Tech and he replied that the subwoofer was probably defective and should be returned to BB for an exchange or BB is to send the speaker out to repair.
I don't think BB will exchange a floor demo for a new speaker and they told me that their warranty is to send the speaker back to Def Tech for repairs and Def Tech said that they require their dealers to handle the repairs.
I made a mistake by buying a demo speaker from BB. It sounded great in the showroom but it's too noisy in there to adequately give the speaker a thorough demo. The fact that one of the screws on the subwoofer showed wear tells me that they did something to that subwoofer and I would think that Def Tech wouldn't be responsible for the cost of repair. Tomorrow everything goes back.
I will show BB the e-mail from Def Tech.
I bought a Carver amp, Carver Center speaker, and Sony DSP from Circuit City years ago and I still have them. If I had purchased this from Circuit City they most likely would have repaired it themselves.
post #2441 of 5215
Hi all,
I contacted chet about using Mythos 2 as center channel. as he quoted, there is no technical difference between 2 and 3, only thing is if you place the mythos 2 as center channel definitive logo will be vertical and the speaker might tilt a bit forward.
so if you can manage the speaker placement I think Mythos 2 will be best at this price
post #2442 of 5215
Actually perfect. My center channel will be on the mantle which is pretty high. A slight downward tilt will have it angled better for listening.
Thanks for the help! At that price, it's pretty unbeatable.
post #2443 of 5215
I just ordered 7 of Mythos2 spkrs, I got 3 yet to receive others, I haven't opened yet, I am also looking for an advice on using all Mythos 2s in 7.1 system with Onkyo 804 and Monster Cable SUB. I am not sure how its going to turn out to be, I heard if you have same spkrs for all channels sound will be quite natural. I have to wait and see.
post #2444 of 5215
i have the following for my HT setup...
2 x mythos one
1 x mythos three
2 x mythos two
1 x M&K MX-200
i was just curious if my sound will be affected that much more negatively because of the difference in size of the woofers between the mythos one and the mythos two/three...
essentially, is it a big deal that i did not opt for the mythos eights...the setup listed above was such a good deal....whereas if i had replaced the three and the two with the eights...the price of the HT setup would have shot up by more than 1200...
thanks...
post #2445 of 5215
I went to a Magnolia Only store and was able to buy their floor models, price matching the BB price. These floor models appear to be taken care of much better than the BB floor models.
We ran the test tone for both speaker subwoofers and mine had the extraneous noise and theirs did not.
Night and day difference between BB Magnolia and Magnolia Only stores. I would feel very conifident buying a Magnolia Only open box in the future.
post #2446 of 5215
2 x mythos one
1 x mythos three
2 x mythos two
1 x M&K MX-200
thanks...
You might feel better to know that when the ones were first released, they were paired with the three center. There were no 8s, 10s or 9s (released in that order IIRC). Should be fine if it sounds good to you. The tens were meant to keep up with the newer supertowers. Of course, if you get a chance for a great deal on an 8... (Enjoy!)
post #2447 of 5215
Use those technic's first then run the external sub LFE and level it with the receivers test tone or if it has Audyssey or MCACC room correction.
If one is blending a external sub , you still use the same steps then bring the external sub into play last. You use your spl meter to get the level correct. It's so hard to do by ear almost impossible. My ear you can blend it to taste but it will not be properly calibrated.
post #2448 of 5215
I'm sorry to hear you have to go through all this but the speakers are worth waiting to go out for repair if thats what BB will do for you. Def Tech will repair and replace anything wrong. They are a good company and will help you with anything you need.
Good luck , don't settle for another speaker due to price or I can have it right now , wait it will be worth it.
post #2449 of 5215
2 x mythos one
1 x mythos three
2 x mythos two
1 x M&K MX-200
thanks...
I think you'll be very pleased with your Mythos configuration. If you check the first post on this thread, you can find links to a couple of pro reviews of your exact Mythos configuration. The three is a good center match for the ones, and was the original flagship center for the Mythos line.
post #2450 of 5215
Thank you so much for your advice.
Fortunately I went to return the Mythos 10 at a Magnolia Only store first. The sales rep was very helpful. We tested their floor model STs and my ST. My ST made the noise and theirs didn't. He agreed to price match BB for their floor models. I kept the Mythos 10 and got a good set of floor model STs from Magnolia Only and returned the defective STs to BB.
I agree with you on Def Tech. Chet has been very helpful and responds very quickly. He sent me the owner's manual and some missing parts for the floor model.
post #2451 of 5215
I'm thinking of purchasing the Mythos STS and as such, was thinking of getting a center channel speaker as well. I've read that reviewers generally mate the STS with the Mythos Nine. Is the Nine the best match? Or should I consider others, such as the Three, Seven, or even the Mythos Ten?
Any suggestions would be appreciated. Thanks!
post #2452 of 5215
Asked and answered numerous times already. The 9 is the preferred match for the STS. The 10 is not necessarily better or worth the extra cost for that configuration.
post #2453 of 5215
Thanks for the info.
post #2454 of 5215
Awesome , I'm glad you got taken care of. Chet is a cool guy. I have delt with him on a few questions for the future as well as some setup tips.
post #2455 of 5215
After retiring my BP10's and my CLR1000 to the bedroom for the sleek Mythos two's, I thought the center channel sounded a little weak. Thought about going for the Eight. Also thought about getting One's and having the Two's for surrounds. Can anyone give me some opinions on their Mythos One's. I also took advantage of the great Amazon price and bought three Two's. I didn't want silver so I painted them black and ordered three grills from Chet at $22 each that includes shipping. They look great.
post #2456 of 5215
Mantis10, please help me figure out how I'm going to do this...
I trying to understand how to incorporate listening to my SACD and DVD-A collection with the Mythos ST's and NO subwoofer.
I think I have a couple of options:
1. I can connect my SACD/DVD-A player to my receiver via HDMI and let my AVR handle the audio bass management like any other multi-channel source (it will send all freqs to my ST's through normal speaker wire as long as they are set to "Large" and my AVR is set to "No Subwoofer."
2. I can connect my ST's to my AVR with both speaker wire and LFE cables and set my speakers to "Large" and AVR to "Subwoofer Yes." Then I can connect my SACD/DVD-A player to my AVR via 6-channel analog RCA cables. This way, the LFE channel will simply go to my ST's via LFE.
Assuming I choose #2, how will the ST's internal crossover interact with the single bass management crossover setting in the SACD player (presumably 80Hz)? Isn't it likely that I will either have a gap in the frequency range, or possibly a crossover overlap? Also, when I watch movies, how will all the BD codecs react to this method of hookup? Won't my ST's get double bass information (normal bass going to the "Large" speakers through speaker wire + LFE freqs traveling through the LFE cable)? How will the ST's sort out all the different low freq information coming at them?
post #2457 of 5215
Ok lets slow down and take one step at a time.
Please list your complete system and I can tell you how to set it up for best performance.
post #2458 of 5215
Panasonic TC-P58S1 plasma HDTV
Pioneer Elite SC-25 AVR
Oppo BDP-83 BD/SACD/DVD-A/CD
Direct TV HD DVR
XBox360
Wii
Mythos ST fronts
Mythos 10 center
SM450 rears
post #2459 of 5215
Direct TV HD DVR
XBox360
Wii
Mythos ST fronts
Mythos 10 center
SM450 rears
Ok cool , your system is very close to mine , here's the best way to set it up for all listening experience.
1) Wire the Oppo only in HDMI. Forget about 6 channel in's. The Oppo can pass all audio over HDMI and is the cleanest way to do so. All digital is great.
2) Wire everything HDMI. There is no reason to use analog anything unless your using zone 2 and 3. Then you will need analog for listening in other rooms. Stupid receivers most do not have a DAC for zone 2 , just analog switching. Life would be much simpler if they would pull audio from digital and send it out Z2 and Z3.(Sorry pet peeve of mine)
3) For the ST's , run good quality speaker wire like Liberty 14-2 . You can use heavier wire but 14 gauge is fine for runs under 50 feet. Don't use cheap speaker wire as most degrade itself over time. many good companies make great quality wire so you pick what you like.
4) Run LFE to both Towers. use a high quality Y splitter like Tributaries or what ever brand you like as long as it's good built quality. It's a shame the SC models except the SC-09 don't have dual sub outs. If I had the extra money I would pick up a SC09 just to have this. It's nice to tune one sub at a time but I have a way to do some of that we will get there.
5) Set the ST's in large and Sub to yes. This is how DEF TECH wants you to set them up and it works great. No worries about double bass and all that other stuff. Not a problem as the ST's are designed to be Large main channels and Subwoofers in ones system. They have been doing this for a very long time and take care of the crossover points internally.
6) Use MCACC for all tuning of the system. This will calibrate the system damn close to correct. You can rely on it as I feel it's the best in the business built in. I prefer it over all other room correction systems. I get the best results when using a Elite receiver over all others in this area.Please read the manual for proper calibration, I can answer any other question on MCACC you may have after getting a basic understanding.
I use my system for SACD and DVD AUDIO as well as cd listening. I also have a Apple TV loaded with Lossless music which sounds exactly like the cd version . I find the internal DAC's on the Pioneer to be amazing for a receiver at these price points. I have the SC-07 and I love it.
Placement before all this and room correction is so important. You can make your speakers sound so much better with just proper speaker position and then calibration. Use the 3/4's rule when setting up the ST's. I have tried many positions and I find this to be the best. What that means is measure the distance from your screen to your seating position. Then take 3/4's of that measurement and space the ST's that far apart. Toe the ST's for the tweeters to meet just behind your head. Think of a Triangle. Make the point end just behind your head. This will align the Tweeters for the best sound stage and imaging. You will be amazed how good the ST's sound after tweaking and dialing them in. The distance from the side walls and back wall also play a huge roll on over all performance.
Go to the first page of this thread and there you will find my sub calibration technic. It works wonderfully and you will get the best musical performance out of your ST speakers. Most make the mistake of not balancing the subs before running room correction.
Do all that and report back. Ask any questions you like. You will notice leaps and bounds afterwards. Like getting new speakers again.
Good luck.
post #2460 of 5215
Good luck.
Thanks for the reply Mantis10. Please bear with me - I understand the "how" part of wiring the Mythos ST's. What I don't understand is the "why."
What sonic difference is there between hooking up the ST's via LFE channel and running them "Large" / "Subwoofer Yes," or using just speaker wire and running them "Large" / "Subwoofer No?"
It seems to me that if I run my AVR "Subwoofer Yes," I'm telling the AVR to send freqs below 80Hz through the LFE channel. And if I run the ST's as "Large,", then I am telling the AVR to send ALL freqs (20Hz to 20KHz) through the speaker wire. Since both outputs feed into the ST's, that means there are, theoretically, two sets of signals from 20Hz to 80Hz (one in the LFE and another in the speaker wire) going to the ST's, and two crossovers are involved (one in the AVR splitting the signal up, and one in the ST putting them back together).
If I just use speaker wire only, then only one full-range signal leaves the AVR and goes to the ST's, and the ST's internal crossover sends the freqs where they need to go. Even the ST owner's manual says this is the simplest method - it gives me "all the benefits of the discrete LFE signal" without the complexity of additional LFE cables, and splitters.
But, this doesn't explain how all this works in the analog domain. I know you think all digital is best, but isn't there some truth that 6-channel analog is the purest, most direct means of transmission for SACD/DVD-A? In the HDMI world, DSD is converted to PCM, which is then converted back into DSD before being converted into analog (assuming all that HDMI handshaking goes smoothly). Why isn't it better to let the SACD player's DAC convert the original source from DSD to analog and bypass all digital conversion and bass management?
Great topic, by the way - thanks for helping to teach me!
  Back to Forum: Speakers
