Originally Posted by Mantis10
Use those technic's first then run the external sub LFE and level it with the receivers test tone or if it has Audyssey or MCACC room correction.
If one is blending a external sub , you still use the same steps then bring the external sub into play last. You use your spl meter to get the level correct. It's so hard to do by ear almost impossible. My ear you can blend it to taste but it will not be properly calibrated.
Cool thanks.
Can someone point me to a SPL for dummies link on how you setup your speakers in this manner before you run Audyssey? I just bought a Radio Shack unit last week.
Also, is there a point where a sub 'could' out play your ST's? I am looking at the Submersive of F113 and they are expensive, but get rave reviews. Will either of these units or even the PSB Ultra 13, out shine or overpower may be a better term my ST's and 10 and Gems? I know Audyssey will help smooth all that out, but is that 'too much'?
