Originally Posted by bodosom
Don't do that. If you don't have stand-alone sub-woofer don't say sub-woofer=yes in your AVR and don't hook it up via sub-woofer out except ...
This is a gross simplification however good level matching can be tricky. If you have XT32 you can temporarily use the sub-woofer output to set the output level. I think the lesser versions will also do level checks but it's harder.
Fortunately this isn't the bipolar thread. While Audyssey isn't perfect the idea that a typical listener can level match and time align a multi-channel system by ear better than Audyssey is silly. Yes the buil-in amps make things a bit trickier but as long as the powered portion is close Audyssey will fix it up. Particularly if you don't make the mistake of running a center channel as LARGE/Full-Range.
Thanks bodosm,
I will re-run Audyssey and just stick with what it sets my speakers to.
If I set sub=no for the calibration, then later set sub=yes afterward Audyssey is complete, would I be ok? The reason I ask is for the bass shakers they need a signal from the receiver's LFE. If I set sub=no I am pretty sure they will not work...
