AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › What is this on my screen>
post #1 of 29
http://img508.imageshack.us/my.php?image=img8854cx7.jpg
Anyone have any idea of wtf this is? I dont think its a dead or stuck pixel/pixels. I cant see it from where i sit, but it still bugs me that it is there. There is a smaller one towards the right too. It almost looks like the screen is dirty, but its under the screen.
i posted this on another forum and got this reply:
"Dust blob inside lens assembly of your projector, if it is not a sealed lens assembly?
You can google for (infocus) 4805 dust blob to see discussion of issue on another projector. "
Should i worry about it if i cant see it from where i am sitting? What exactly is it?
I posted this in the thread for my tv, but made a new thread since no one was answering and it kind of applies to all tvs with a screen lol.
post #2 of 29
If that's a rear-projection TV, you could indeed have something inside that's casting a fuzzy shadow on the screen. It happened to me. I had this visible fuzzy blob at the bottom of the image. Pulled the back of the set and found a spider web along with a dead spider. The spider was in the light path to the screen and casting a small shadow. Got rid of that, and cleaned a fairly heavy layer of dust off the 3 CRTs, and TV looked like new again.
post #3 of 29
Its an LCD TV. I should've mentioned that . LN46A650.
post #4 of 29
Has it always been there? Could have been caused in manufacturing
post #5 of 29
yeah it has always been there. should i care if i cant see it from where i sit? this is so annoying lol. that or risk a tv with other problems/stuck/dead pixels.
post #6 of 29
bump
post #7 of 29
Anyone? I think im just going to live with it since its impossible to see from where i am sitting. damn this imperfect technology!
post #8 of 29
Your issue is minor compared to the huge dust blob issues I had with my Mits WD 65733. But thanks to those dust blobs they replaced my TV with a WD 73835 at no charge.
post #9 of 29
haha thanks for that.
Its actually probably smaller than it seems based on the picture. Its impossible to take the pic from where i sit and be able to see it, which should mean that i shouldnt worry so much, but yeah. Its just annoying it is there, but i dunno if i wanna do anything about it.
post #10 of 29
Depends what sort of clouding/flashlight issues your panel has,if any?
If you cant notice it from where you are watching from,and your panel has no noticable clouds etc,then I would personally stick with what you have now.
You could end up with a panel that has very bad clouding .
post #11 of 29
Yeah, makes sense. I'm thinking ill live with it...its so minor.
thanks for the help everyone!
post #12 of 29
Well, in addition to this, when i put it on a white screen to see if there were any other dead/stuck pixels, i found a spot a few pixels wide/high, right at the area where the screen meets the frame, that is all messed up, like a bunch of stuck pixels. i found another area similar to this at the top (the other is at the bottom), but smaller.
in addition to this i have minor clouds and some lights at the top two corners, and i had some stuck pixels that i unstuck myself when i first got it.
Should i do an exchange? Its hard to see these problems, but im scared that i got a bad panel that will screw me later on.
post #13 of 29
if you can at no charge to you ,i would do it now .
You paid for a perfect tv and you should get one
post #14 of 29
hey guys I have a very similar problem to what test is showing on his 650.
Here it is on my 40XBR6
http://i42.tinypic.com/jp7nk1.jpg
http://i43.tinypic.com/117h6ir.jpg
http://i44.tinypic.com/16bzn7m.jpg
Any ideas what I can do to fix this or what the problem is?
Im thinking of getting the LCD panel replaced.
post #15 of 29
Hi Viper & Test,
Its such a tough call as to whether to swap ,as the risk of getting something worse is there.I'm not sure what the cause of your problem is,but its down to what you notice when watching films/tv etc.
I had really bad clouding and flashlighting on my first 650 panel,and it was noticable in normal viewing (dark films like Blade Runner,The Crow etc ),so it was a fairly easy decision to have a replacement panel fitted under warranty.
I thought about living with it,but I just couldn't,my eyes were drawn to the clouds every time a dark scene came on.
I had some luck in getting an "almost" problem free panel,no clouds visible at anything but high backlights,and very minor flashlighting from one corner.
I dont think theres many "perfect" larger size LCD screens about,almost all exibit some form of problem that people like us notice ,and get annoyed by.
Basically,if it was me,and I kept seeing the imperfection,I would have it replaced.
It's a horrible position to be in though,very frustrating to have these sort of issues when you have laid out this much cash.
post #16 of 29
I forgot to mention ,it makes me wonder whether a lot of the problems like flashlighting are caused by the amount of torque applied to the set's case screws.The techs that replaced my panel were muttering to each other about the tightness when they came to undo the screws to remove my existing panel.
The panel they fitted had never been fixed to anything before,and was almost perfect.Maybe its just a coincidence,I'm not sure.
post #17 of 29
Wow, that is interesting, thanks for posting. I will probably make a decision in a couple days. This really is frustrating...i guess $1500 isnt worth what it used to be.
post #18 of 29
yeah...well I think this is a piece of dirt on the top left part of the screen,or maybe a small crack. Whatever it is its annoying me so i called today and will be getting the LCD panel replaced hopefully sometime next week.
I only have one flashlight and some minor clouding on the top left part of the screen. I really hope my next panel wont be any worse...
post #19 of 29
Does that mean theyre replacing the entire tv?
post #20 of 29
um, i think those spots are fading if thats possible lol.
post #21 of 29
no they are changing the LCD panel inside the TV. Its a PART
post #22 of 29
The dark spots are crap in the light guide in the backlight. It also appears to have some non-uniformities and they are "clouds" (what a dumb term) caused by, as mentioned above, by uneven pressure of the plastic housing.
There is no cracks. Cracks are fatal, immediately (and they don't look like this).
These problems are inside the LCD cell inside the set. The cell needs to be cleaned but they will probably throw it away after they unsucessfully convince you that its in your head.
post #23 of 29
So will changing the LCD panel (which im doing) fix my problem?
post #24 of 29
Sadly, only an airgun is really required to clean out the crap. But it is inside the LCD inside the set, so yes. The LCD manufactures have specs on "black spot" and 'white spot" contamination (size and density).
I don't know the brand by reading your part number, but this level of contamination speaks to second tier manufacturers who buy second grade displays. Sometimes quality has a price.
post #25 of 29
uhh mines a sony. I dont think they get much more expensive than that.
post #26 of 29
Bummer.
post #27 of 29
im just hoping the new panel im getting soon will fix this issue without creating anymore...
post #28 of 29
mine is a samsung. im still debating what to do. you think i should give a call to samsung? would they even be able to fix this? it has faded a little.
post #29 of 29
get them to replace the panel
