I have the DMR-E85H, actually now sitting in a box in the garage. I've replaced it with a DMR-EZ27. The E85 froze up one day and whenever I tried to cut it on it just seems to stay in boot up mode and never come on. I tried unplugging, forcing ejection of the disc, but nothing worked. I've searched these forums and haven't found similar errors. I did check the firmware once concerning the dreaded U99 error and found the firmware to be up to date.
I do miss a hard drive, even though I have a DVR through my cable box. I record a lot of movies and always liked being able to edit the beginning and end to get rid of the extra material. (Seems no one starts or ends their movies exactly on time.)
I do like the EZ27 being able to record on DL discs. A nice feature to be able to record a +3 hour movie. On the E85, I always spit anything greater than 3 hours into 2 discs. Panasonic claims the EZ27 four hour mode is the quality of the old 2 hour mode, is this true?
Short of tossing the E85 in the trash, are their other quick fixes I can try? Can the firmware have gotten corrupted, try a firmware update again? If it is in perpetual boot up mode, is the hard drive trashed? Can it be replaced with any desktop hard drive? That seems to be an easy replacement. Any other ideas on how to get it working? If I need to send it in for repair, is it worth fixing? I've kind of gotten used to the EZ27 and the fact that I can't edit.
, but if there's one thing I avoid if at all possible its a soldering iron: I know my limits, and I'm a klutz with solder. With a lot of time and stress, I managed to replace the power supply caps and drive motor in my vintage Thorens TD-145 turntable, but decided after that episode to quit while I was ahead
. Good luck!
