AVS › AVS Forum › Video Components › Home Theater Computers › HDCP Problems
HDCP Problems
post #1 of 3
I'm running Vista 32 Home Premium, a Sapphire 2600XT PCIe Card. When connected to an HP w2207h, the Cyberlink BD Advisor is all green and I can happily play Blu-Ray discs. When I move the HTPC to connect to a Pioneer PDP-507XD Plasma, the BD Advisor shows red for the Video Connection and I end up with an HDCP error 0110. I have re-installed so many times and varying orders, with no success. According to all the specs I have, all the components are all HDCP compliant. But still no success...! Any ideas...? Thanks
post #2 of 3
I don't see any statement in the following specs that state that the Pioneer is HDCP complient.
http://www.pioneer.eu/eur/products/a...7XD/index.html
You may have to swith to the component interface to play your BR DVDs using 1080i.
post #3 of 3
Although not ideal you could connect your PC to the Pioneer by VGA. Until the image constrant token (ICT) is enabled it should work perfectly.
