I've finally decided to get my first projector, and hope someone can give me some feedback on the final choice. Also, I have no idea what screen to get, so if you have suggestions for that I would appreciate it--it will be a fixed, wall-mounted screen.
Criteria:
I do not have full control of ambient light and, even if I did, I would still want to be able to watch TV--sports, news, etc.--on the weekend without having to black out the room, so I want a projector that will have great quality for nighttime movie watching but also be bright enough for natural light. I will sacrifice ultimate picture quality for extra brightness.
I'm torn between spending the least I can to get a decent projector now (maybe 720p for under $1000), knowing that I will upgrade in the next couple of years; or spending more ($2000-$3000) to get a 1080p/24 that I will have for several years.
I'm sensitive to picture and sound quality (worked in film business for years), but I also understand that I am not spending enough to get the ultimate theatre this time around. I tend to go for quality over marketing hype when I buy techie stuff.
Room:
It is a family room/TV room with attached kitchen and view to backyard pool, which is why I do not want a blackout theatre.
Dimensions:
Width: 18' (screen on 18' wide wall, limited a few feet by corner insets)
Length: 23', with kitchen extending another 12'
Height: 8.5'
Projector placement: hang from ceiling about 12.5' from screen wall.
Main seating: about 14'-15' from screen wall.
Screen: planning 110" or 123" diagonal 16:9
From my own research, the finalists are:
Panasonic PT-AE3000: for brightness, 1080p, and positive reviews.
Epson PowerLite 6100: for brightness, 1080p, good reviews, and price.
Sony VPL-AW15 (or 10): for price, but will it be bright enough?
Sony VPL-HW10: I've always been a Sony TV fan, but it's a little bit expensive and will it be bright enough?
Epson Pro 1080 or 1080 UB: ???
Any other suggestions are welcome for projector or screen...
Thanks, in advance, for your help.
Criteria:
Room:
Dimensions:
Height: 8.5'
. The smoothscreen technology on the AX is what makes it known as the 'poor mans 1080p PJ'. Though there are better discounted older higher end 720p PJ's out there but finding them in stock is not easy.
