AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › TV guide channel.. How does it work??
post #1 of 7
I was just curious how the TV guide channel works? Does it rebroadcast a national feed? Or does each cable company have a specific system to download TV Guide Network's programs and rebroadcast them to cater to each system?
I just got TV guide network added today. The guide is on the bottom of the screen but nothing at the top except a TV Guide logo and no sound.
post #2 of 7
post #3 of 7
I was interested in TV Guide Channel..
Right now the network is suppose to be showing the program InFANity. But its just TV listings on the bottom with a TV guide logo on top.
post #4 of 7
You mean the specific channel with TV listings? Like my channel 3?
I think they tailor it to local markets. I just looked and mine, after scrolling through the analog band listings (channels 2-99), shows local (to me) weather, and then my location (roughly), and then the listings again.
Above the listings is some celebrity news program which I assume is InFANity (as that's what the guide lists here as well.)
Might be a glitch in your local cableco's feed or something if you can't see the program above the listings.
post #5 of 7
Not familiar with the "channel". Satellite? Cable?
Have you contacted your provider?
post #6 of 7
Originally Posted by Ratman View Post
Are you referring to TVGoS?
http://www.dvdplusrw.org/Article.asp...&sid=-1&aid=79
Ratman is that a digital interactive guide,our digital guide looks just like the
analog guide, only difference is you can control scroll it and do certain things
otherwise it sucks.
post #7 of 7
Those used to be done using Amiga systems with Video Toaster hardware; these days it's some sort of packaged system running their special software. They actually have the system at their headend generating the video output for broadcast. If they're just sending a logo with no programming info, there's something wrong with their local system - either it's failing to get the channel list or guide info, or something's gone sideways in the software. Call them up and tell them.
  Back to Forum: Cable, Digital Cable - Non-HDTV
