AVS › AVS Forum › HDTV › HDTV Technical › Coupon Eligible Converter Box (CECB) › HD converter box?
HD converter box?
post #1 of 6
Forgive me if I missed it in my search, but I've got a 5 year or so old 23" LCD TV that can do 720P but only has an NTSC tuner for OTA TV. Is there such an animal available that would allow me to capture OTA HD TV without spending an arm and a leg? From my limited research, it appears that most of the DTV converter boxes are only SD. It would be nice to get HD on the HDTV. My other options are convoluted with either a PC hooked up to it or an extender from my VMC.
post #2 of 6
It is possible to buy a digital tuner for your tv but they are more expensive than the computer video capture cards. What are the inputs on your LCD? Does it include component and HDMI inputs?
post #3 of 6
HD Tuner $79-- Centronics ZAT502 HD Terrestrial Digital ATSC Receiver (ZAT502HD)
http://www.solidsignal.com/prod_disp...?PROD=ZAT502HD
post #4 of 6
That and other HD tuners can be found in the HDTV Technical forum
http://www.avsforum.com/avs-vb/forum...sprune=30&f=25
You might want to check out Ken's sticky
http://www.avsforum.com/avs-vb/showthread.php?t=179095
or the AVS thread talking about the ZAT that WeAreNotAlone69 mentioned(looks like the link actually talks about the 501?)
http://www.avsforum.com/avs-vb/showthread.php?t=858602
post #5 of 6
Thanks for the feedback guys! For some reason I wasn't getting notified of responses.
post #6 of 6
how about rca dtc-100 from ebay ?
