I have a 3 year old (2005) Sony KDF-42WE655 television. It works great hooked up to cable box to get HD. I have a buddy that has a newer Sony television in which he hooked up an Antenna to it and plugged it into the 75ohm (RF) connector on the back of his television and is able to watch HD over the air channels as well as digital channels. I have gone to the Sony web site and double checked that this model has a built in QAM and ASTC tuners. When I hook the same antenna up to my television (he only lives down the block) I don't get any channels. Is there a configuration that I need to set on the television? I started to read the manual and it says only HD channels can be received using component or HDMI connectors. That explains the HD but I still don't get any of the digital channels.
Anyone have any things I could look at or try?
Many thanks!
Many thanks!
