Originally Posted by johnnyb05
i notice pretty bad judder on my KRP-600m. when output is set to 1080p24 on my samsung blu-ray player, watching casino royale the scene where bond is sitting at the poker table the camera pans left to right, it looks pretty bad. i tried advanced, standard, smooth and off. advanced is the worse. smooth makes that scene look better and others where the camera pans, but overall smooth adds more problems then it fixes. now this was all with my blu-ray directly plugged into display, with a top of line bluejeans cable. i NORMALLY have my sources into my DVDO edge. which the judder looks the same. the edge has a judder test, when i run it with output set to 1080p24 the white bar moves slowly and shows tears and judder. when output on edge is set to 1080p60 the white bar moves faster and it is nice and smooth. it looks like KRP doesnt like 24 frames signal! how can this be?
I played the dark knight with a pioneer blu ray player through advanced mode for film and it looked fine by me. I may have to rent casino royale to test this out, but so far 1080/24 playback has been good for me. I just got planet earth today in the mail too. if you find some scenes where it's bad, let me know, maybe I can test it out on my 600m and let you know.
. I am probably going way against the mainstream here, but on mine for cable viewing specifically, I set 3DNR and Field NR both to High. I think it really helps with the compression/noise issues for cable watching. I also found that Purecinema set to Off is best for me for cable watching in trying to eliminate judder. I am using Verizon FIOS DVR. However, for DVDs though, I turn all of the noise reduction stuff off and use Advanced purecinema. Not sure about the 24 bit thing...sorry!
