AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › The Official Pioneer 9G North American KRP-500M / KRP-600M Owner's Discussion Thread
The Official Pioneer 9G North American KRP-500M / KRP-600M Owner's Discussion Thread - Page 60
post #1771 of 4963
Originally Posted by carftopher View Post
Could you please clarify? Thanks in advance.
http://art-head-start.com/color-tree.html
post #1772 of 4963
Well I finally got to test my 500m from Vanns and so far so good . It turned on fine but man was that free stand a pain to install. I missed the old 5020 stand where you could just slide the tv down on the stand. I have a slight buzzing that is a little louder than my older 5020 but honestly I can only hear it if I go behind the plasma. If I am sitting in front of it even at 1 foot, I can't hear it (and that is without any speakers or audio connected). All my kuro's have buzzed to some extent but this is the most noticeable. I'm just glad it doesn't effect normal viewing. I also don't particularly like the placement of the HDMI ports. First it was hard to insert the cable (I had to physically push harder than I would have wanted) and the cable is almost cramped back there and has a little to much give for my liking (and I am using the thin, flexible tartan cables from bluejeans). You can tell the HDMI cable actually moves a little after you insert it. I just worry down the road of having a bad HDMI port but hopefully that won't happen. Otherwise I love it so far. The free stand is way better than my old 5020 stand quality wise.
post #1773 of 4963
I've been looking for a 600m for a couple of weeks now, but have been unsuccessful. It seems that most vendors are either out of stock, or priced rather high. Could someone please send me a PM if you happen to know of a vendor (preferably a forum sponsor) that has these in stock?
-Thanks
post #1774 of 4963
supposedly a lull in the 600M stock while Pioneer repackages whatever stock is still in the supply chain.
post #1775 of 4963
Hi YOTR,
I too ordered from vanns and will be receiving the stand as well. What was difficult about getting the stand on?
Also, this is my first plasma coming from a 47' Panny RPTV. How "apparent" and "annoying" is this kuro buzz? Would someone coming from no buzz be affected by it?
a newbie here. after reading about the 500m here for the last few days, I was sold that this would be a very cost effective way for me to have an awesome set for a while to come. can't wait to get mine.
post #1776 of 4963
Originally Posted by mfb View Post
I have been away from the thread for about a week. How are we doing on panel buzz?
I have noticed a pretty decent buzz with mine. Yes, going to power save 1 does help but I don't want to compromise the PQ.
I didn't notice this much noise when I was running thru the breakin process.
Should the buzz increase or decrease (or neither) as we add more hours to the set?
comments?
Yeah, my 600m buzzes. The volume of buzz depends on what's on the screen. Brighter scenes with lots of contrast seem to buzz more. And as someone else mentioned, the buzz is directional (ie. it's loudest when the panel is pointed directly at you).
Just guessing here, but I wouldn't think the buzzing would increase or decrease based on the age of the set. The only thing I've heard that can affect buzzing is elevation (the higher the elevation, the louder the buzz -- and I'm at 4500 ft).
The buzz bothered me when I first got my 600m, but I don't think about it much any more. I also leave my set on Power Save mode 2 which attenuates the buzzing quite a bit. Occasionally, I'll flip back to Standard (Power Save off) just to see how the picture changes. More often than not, the picture looks identical. Sometimes it's a bit brighter with power save off, but it's not significant enough for me to worry about. And if I want more brightness/pop, I just switch from Pure to Standard picture mode.
For me, buying a Kuro is kind of like buying a new car. In the beginning, you stress over every tiny detail and every perceived flaw -- no matter how small. You spend the first couple of months washing your car every other day lest it get a spot on it. But after a while, you settle down and just enjoy it for what it is. That's where I'm at with my Kuro. Just enjoying it for what it is -- a sweet display.
Contrary to what some people suggest, a Kuro won't change your life (unless you lead a pretty limited life). But if you enjoy film and (quality) television, it WILL make that part of your life a heck of a lot more enjoyable.
Anyway, sorry for waxing philosophical... It's late, Roberto go leepy now
post #1777 of 4963
Originally Posted by -FuSioN- View Post
Hi YOTR,
Well on all of the Pioneer plasmas I have owned (5080 and 5020), the stand slid down on Plasma itself (actual holes inside the plasma that the metal pipes went down through). This way you could effectively lower the plasma onto the stand. With the 500m, you have to lay the plasma face down on a surface (scared me the entire time......lol) and then bolt the stand to the outside of the plasma on the back. Not a huge deal but kind of a pain.
The buzzing is subjective. Do I hear it when I am right up on the plasma looking behind it? Yes definitely. Do I hear it from my viewing distance? After listening again I can hear a very subtle buzzing with no sound on at all. It fluctuates depending on what color is on the screen. You can alleviate this if you change the power save mode. Save mode 2 actually almost eliminates the buzzing entirely but it does darken the screen slightly. I haven't had a Kuro that doesn't buzz yet. This is the worst offender out of the four I have had but I want to stress that it is minor. It is a little worse than my 5020 that I sold but not a deal breaker. All plasma's tend to buzz somewhat but Pioneer is known to do it way more than others. I had a tech out with my 5080 about a year ago but usually the buzzing can't be fixed. It can be reduced but usually not by much.
Bottom line, don't be worried about the stand and don't obsess over the buzzing .
post #1778 of 4963
I noticed that to. The buzzing was definitely more noticeable when I was sitting dead center in front of it. It isn't a deal breaker and I know all of them are going to do this to a certain extent. I noticed that with the power save 2 mode also. It almost eliminated my buzzing completely. I agree about the set. I love it and yes I will be anal the first few weeks like I have been with every tv but they all have issues. You just have to find what you can or can't live with. Nothing is perfect. Not even a Kuro .
post #1779 of 4963
This problem is eating at me. Im getting extreme judder from all sources. Its most noticeable on quick pans left and right you can literally see the objects stuttering. Its giving me a headache. On pans up and down im getting a picture that looks like someone wiped sulfuric acid in some spots of the screen. Mostly noticeable on whites. Maybe the phosphors have to settle across the screen? Figures I wouldnt get a cracked screen but have everything else wrong internally.
post #1780 of 4963
I set up my 500M on its stand yesterday and I am very impressedby the PQ so far. I plan on calibrating it with my i1Pro, but even uncalibrated, the color and black levels (which are amazing) are excellent. It will be interesting to see how it measures before and after compared to Elite and ChrisHerberts.
As far as some the items that people have mentioned:
- The free stand from Vann's is odd in that you don't slide the display onto it, but if you have a safe elevated surface to lay the display face down, it is fairly easy to attach. They key is to follow the instructions - even if they don't seem to make sense at first. The display does appear to have slots for a stand, maybe one of the swivel stands slide into those slots?
- I can hear a low buzzing if I place my ear within 6 inches of the back panel, but it is nothing unusual or audible from even 1 foot in front of the display.
- I haven't seen any lines or judder from any sources, including a Sony blu-ray set to 1080p/24.
- I didn't notice any unusual resistance with the HDMI connectors - I am using Monoprice cables. It is a little awkward that they face down, but the Panny monitors are like this too. It comes in handy if you want to wall mount it with a low profile mount.
post #1781 of 4963
The HDMI connections seem normal. Any HDMI input I have ever used (PS3, XBOX 360, HD DVR, etc) all have some give or movement after you attach the hdmi cable. They definitely aren't like component or s video where once it is plugged in, it has pretty much no give at all. This is what has always bugged me about HDMI. I worry because of the looseness on the inputs that eventually they will be damaged or wear out. I just know that when I plug my blue jeans cable 28 AWG (the most flexible HDMI cable out there), you can see the cable move a little forward which is probably just an anal concern of mine .
I checked my buzzing again today and I can really only notice it when I go behind the panel. It seems to be coming from the top right corner. I barely hear at when I am about a foot away from the set but if I put my ear with 6 inches (like you stated), I can definitely hear it. It isn't super loud but definitely audible. It's a louder buzz than my 5080 or 5020 but not by much. As I stated above I don't have speakers connected yet so I just sat down about 7 feet away from the tv. I turned on the discovery channel as I was setting it up. I could hear what I thought was a slight buzz when I was sitting down directing in front of the set. You notice it when the color patterns change. Honestly though all of my plasmas have done this so I think it is a normal thing as the buzz coming from the back of the tv sounds totally different than the slight buzz sound coming from the viewing distance when the color patterns are changing. I can't imagine hearing the buzz or it becoming an issue when I do connect my speakers. My house was completely quiet so I would of pretty much heard anything at that point. I seem to be getting less and less anal with each Pioneer plasma I get but of course I might just be trying to convince myself of that .
post #1782 of 4963
can anyone tell me the height of the krp500m with the included stand from vanns?
post #1783 of 4963
..They definitely aren't like component or s video where once it is plugged in, it has pretty much no give at all. This is what has always bugged me about HDMI. I worry because of the looseness on the inputs that eventually they will be damaged or wear out..
The worst HDMI inputs I have seen are on the SA8300HD cable box -they are loose and a little wiggle of the wire can drop the signal. I actually had to return one box because it would lose it's signal when someone walked past the TV!
post #1784 of 4963
comments?
MFB, I have buzz as well. I hear it very well when the sound volume is very low or off. I'm living with it. I have probably 250+ hours on it.
post #1785 of 4963
Originally Posted by chrisherbert View Post
Last night I finally dug out my i1 and did some preliminary measurements to my 500m.
PURE MODE
As expected, Pure mode measures very, very well. With Gamma set to "2," it's pretty much a perfect 2.2 gamma. Grayscale was also good using the "low" preset, though I was able to improve it with some minor adjustments.
Primary and secondary color points measured well, though not perfectly. I'm not going to mess around with the CMS controls after reading about how easy it is to negatively affect other PQ areas when that's done (that was certainly true of my 8G Elite). Subjectively the color looks great to me anyway.
The ONLY problem that I have with Pure is that it's relatively dim -- I get 37 ftl on a 100% white window at 40 contrast. Much higher than that starts to clip whites and doesn't get any brighter anyway.
SPORTS & STANDARD
Anyway, since Pure was so good, I moved on to "Sports" and "Standard" mode, which are much brighter. Both are easily able to do well over 50 ftl. To me that increased light output really makes the image look great, it really is a "looking through a window" effect (sorry for the cliche).
Of course by default those modes also look horrible...edge enhanced, way too blue, oversaturated, etc.
I made some common sense adjustments to Sports mode (turned sharpness all the way down, turned off all noise reduction and image enhancement, etc) and did some measurements. At first they were encouraging. At gamma mode "1," the gamma measured a respectable 2.1 and was relatively flat. Color temp could be brought in line. I lowered the contrast to 38 (which significantly improved color temp and gamma vs contrast at 40) and still got an awesome 50 ftl peak brightness. Primary and secondary color points were fine.
The problem? The color decoder is way off.
I switched to Standard mode and made similar adjustments (standard is a little brighter -- 36 contrast got me 50 ftl). Its color decoder seems somewhat better than Sports mode. I didn't have time to really get the best of of either sports or standard, but I will definitely be revisting them in the near future. The increased brightness is just too great to ignore.
I thought I'd share my results with people interested in an alternative to ISF Day mode. I'd say that a tweaked standard or sports mode should be very satisfying for many of you. I'll post my settings later.
Curious about those standard settings if you don't mind sharing when your done tweaking.
Thanks in advance.
post #1786 of 4963
I spent some time last night with Standard mode.
With 32 Contrast I was getting around 40 fL. Gamma was off in the higher IRE range, but color was on target with the CMS controls at 0. I'll tweak it more tonight.
Let me ask you all, is 40 fL good enough for most?
post #1787 of 4963
What does 40 fL give you in terms of calibration give you over having standard at 50 fL? Thanks.
post #1788 of 4963
Originally Posted by NCoastTweaker View Post
Do any of you KRP -xxxM owners use a receiver as a switcher for HDMI? I'm asking because many receivers come with the ability to 'scale' Standard Def' input signals to 1080I or 720p (some higher end receivers even convert 1080i to 1080p)
I still receive alot of SD content, and some broadcasters even send SD material out on their HD channels which results in a cropped image. Since the KRP - is a 'monitor' I was
hoping for some feedback with your experiences using builtin receiver scalers or even
outboard scalers...(but those are priced out of my league) I know that many DVD players also have this 'up-rez' feature as well....
I have a Denon AVR-5308CI with the Silicon Optix Realta chip. I know that other brands
use the same, or , the Faroudja brands.. How well do these 'scalers' perform on SD material out to this specific KURO monitor.... is the cleanup decent?
How does it compare to SD material (480i /480p) without upconversion?
+1 on this question - I'm hopefully getting my 600M first week of May, and I'll also be using a Denon 5308CI receiver for video processing - I'd like to know if the Kuro's internal processing is superior. Thanks for all the info on this thread - great stuff.
post #1789 of 4963
A bit of relevant experience: Watching Bluray on PS3 I noticed some annoying judder. I changed the PS3's 24p playback setting from 'On' to 'Automatic' and this seemed to reduce the judder. (This is the only content I've viewed so far)
I finally completed the 'requisite' break-in period of my 500m yesterday (man did that feel like forever) and celebrated with some Iron Man. I used the D-Nice/Elitehome settings in a very dark room. My only tweak was to sharpness. I found the suggested settings left the image a bit blurry (I sit pretty close to the TV) -- so upped the sharpness to -5. Using a PS3 with colors set to RGB limited and TV input set to RGB (16-235) (or whatever it is).
Picture is awesome! I've got a pretty bright room and will be experimenting with some of the daytime settings I've seen suggested here. I'll let you know if anything worthwhile comes of it.
Also, regarding the buzz issue. My set's got an audible buzz. Tone and volume of buzz vary based on what's being displayed (bright screens, etc.) Certainly noticeable in a dead quiet room. Not really noticeable when there's any sound. And yes, using Power Save 2 cut the buzz in half at least. With Power Save 2 and any volume whatsoever, the buzz is not an issue. I do not notice a change in picture quality from Standard (no Power Save) to Power Save 2.
I'll also share my info on the PDK-TS23 stand height issue, which I've seen asked about here. There is just under 4" from the top of the stand's base to the top of the 500m bezel. So if you wanted to place a center speaker on top of the stand base, it would need to be under 4" or else would block the screen.
post #1790 of 4963
Can anyone give me a logical reason as to why Pioneer would limit Pure's light output to only 37 fL?
Edit:
Please disregard my above question. I'm reading some articles on foot lamberts and certain things are making more sense to me.
Edit2:
This quote from Doug Blackburn makes me feel better:
I find 30 fL-35 fL "just right" for viewing in a DARK room.
I only like to use my 500M at night with the lights off, so Pure's 37 fL should be more than enough for me.
post #1791 of 4963
I was hopeful that it would be more in the 45fL range (ie Contrast at 39-40) for more differentiation from Pure mode but if that throws off gamma too much I guess it would counterproductive.
I'd also be curious if User mode might be capable of more accuracy than Standard mode? I had come to the rough conclusion that Standard mode allowed slightly more light output than User mode without white crush and therefore focused on Standard mode. I was using a very crude measuring tool (my DSLR cam) to draw that conclusion and they seemed quite close on light output. Might be interesting to plug your Standard mode settings into User mode and see what the measured differences would be if you get a chance.
Thanks for sharing PBJr.
post #1792 of 4963
Same thing here MFB. 600M with buzz I notice with volume off in a quiet house. Varies with picture content. I briefly had a 6020 that was the same in this regard. I think its normal/typical and not an issue for me.
edit: wanted to note that I am using the standard power mode and plan to continue using that mode only. The buzz is not an issue for me in day to day use.
post #1793 of 4963
Could be to create a market for the Elites, I guess. Or maybe the lower birghtness is considered more appropriate for a serious videophiles. I think the G1's THX peaks at under *30* footlamberts.
post #1794 of 4963
If you're just getting 40 ftl, why not just use Pure?
post #1795 of 4963
I think Pioneer's intent with Pure mode was to, as the manual says, "reflect input signals as faithfully as possible". From what I have seen, ~37fL of light output is in the target range of what the majority of professional calibrators and "studio monitors" would suggest is the correct level for a light controlled environment. More is not necessarily better in the optimal viewing environment Pure mode is targeted for.
post #1796 of 4963
Originally Posted by FlashJordan View Post
I think Pioneer's intent with Pure mode was to, as the manual says, "reflect input signals as faithfully as possible". From what I have seen, ~37fL of light output is in the target range of what the majority of professional calibrators and "studio monitors" would suggest is the correct level for a light controlled environment. More is not necessarily better in an optimal viewing environment.
Thank you.
I need to stop coming to this forum so that I wouldn't be able to "find" anything new to obsess/complain/nitpick about -- and just enjoy my 500M.
post #1797 of 4963
I'm going back and forth on using Power Save 2 to reduce my buzz. You're right that it doesn't produce much change in most images, but it will if there's white on the screen. If you try it with a bright outdoor scene--or better yet a snowy one--you'll see it cuts down the brightness considerably.
It's too bad Pioneer couldn't have produced a hybrid setting--one that would be in Power Save 2 mode at lower brightness, but go back to normal when greater brightness was needed. That way it would really only buzz a fraction of the time.
post #1798 of 4963
Can someone that received their set from Vanns with the stand post a few pictures of it from different angles?
post #1799 of 4963
Can anyone give me a height measurment for the KRP-500M with the PDK-TS23 stand offered by Vann's? This is for my bedroom and I only have 31 1/4" to play with. I have been told that the height with stand is 31 1/32"...if that is accurate, I'd like to go for it. Can anyone help?
post #1800 of 4963
I just measured it. It's slightly under 31 1/2 inches.
This thread is locked
