I calibrated my 500M in Pure mode for a moderaly dim to dark nightime viewing environment - about 32fL. I was targeting this calibration for my SA8300HD, so I set the blu-ray player to 1080i/60/RGB to eliminate as many variables as possible (to do: check 720p RGB for any differences). I am using an i1Pro meter, a DTP94 with a calibration file built from the i1Pro for the 500M (for more consistent low stimulus readings), HCFR, and AVSHD. At this point I have changed only the User and RBG grayscale controls; I have not made any changes to the CMS controls.
Pre-Calibration RGB Balance:
Pure, Contrast 35, Bright 1, Color + 6, Tint 0, Gamma 2, all Pro Adjust settings at defaults, Color Temp: Manual 0,0,0,0,0,0:
This results in a 6200k to 6400k color temp - very good out of the box performance. The gamma was an almost perfect 2.22. One thing that was interesting is that when I switched to Color Space 1, the RGB levels stayed the same. And Color Space 1 looks suspiciously similar to a PDP5020 on the CIE chart.
Post-Calibration RGB, CIE, and Gamma:
My calibrated settings:
Input 5 Sony BDP-350
Signal 1080i/60 RGB (for SA8300HD)
Mode: Pure
Cont 37
Bright 1
Color 7
Tinit 0
Sharpness -15
Color Temp Manual:
RH -4
GH 0
BH -2
RL -3
GL 0
BL -1
Gamma 2
Pro Adjust:
Film Mode off
Text Optimization off
Intelligent Mode off
DRE off
Black Level off
ACL off
Enhancer Mode 2(natural)
CTI off
Color Management:
R 0
Y 0
G 0
C 0
B 0
M 0
Color Space 2
3DNR off
field NR off
block NR off
mosquito NR off
I-P mode 1
drive mode 1
Note that not all of these setting effect the measurements. And of course, you may get completely different results using these on your 500M.
