Originally Posted by
leedom
I have no need for tilt functionality; I just want to mount it as easily and closely to the wall as possible (within Pioneer specifications of course).
Here are some old pix of my Peerless OneMount before I sold my 55" Hitachi. To even see the mount behind the TV, you literally had to be at the wall before you saw it. OK, maybe about a 10 degree angle or so from the wall...
Two of the attached pix show the point at where the mount itself came into view. The third pic was taken directly from the right side, so you can see about how far the arms place the TV off the wall. You probably want the TV closer, but the extra ventilation space - and access to cables/connections if needed - isn't such a bad thing.
Note that I had the arms set at a fixed tilt with a set screw, at about 5 deg. downward. There were three (or four?) fixed tilt positions using the set screw, or you could use the arms' wingnuts to tilt at any angle needed within its range. You can see the set screw just below the wingnut/arm in the side view pic...
