AVS › AVS Forum › Audio › Speakers › Clr 2002 question
Clr 2002 question
post #1 of 7
Hey there everyone, i got my CLR 2002 today and i have a question, on the back it has 2 rows of terminals, one red and black on the top and one red and black on the bottom, now i understand that you will use all these 4 terminals if you are BI AMPING but i am NOT..
I just want to hook it like a regular speaker, so i just plugged in my speaker wire into the TOP row of terminals, is that how i hook it up regulary?
And i also have another question, when i just took the speaker out of the box there was also a set of 2 JUMPERS on the back where the terminals are and it was connecting the top row of terminals and the bottom row, i took these jumpers out, do i need these or these Jumpers or they are only for bi amping?
post #2 of 7
And i also have another question, when i just took the speaker out of the box there was also a set of 2 JUMPERS on the back where the terminals are and it was connecting the top row of terminals and the bottom row, i took these jumpers out, do i need these or not?
You are not bi-amping or bi-wiring so install the jumpers in place.
post #3 of 7
Ohhhhh so i NEED to have the jumpers in place yea? and its fine that i plugged in the speaker wire into the top row of terminals rather than the bottom row, basically it doesnt matter afterall whether i plugged it at the top row or the bottom if the jumpers are in place right?
post #4 of 7
That's right.......once the jumpers are in place you can hook up to the top or bottom terminals.
post #5 of 7
Ahh ok got it man, what i did is i took out the speaker wire that i had connected at first and i placed the jumpers first and THEN plugged the speaker wire back into the top row.. i knew that something wasnt sounding right with the speaker
i have one more little problem, installing the Logo, see, i found the 2 small holes where the logo is supposed to pop in but it just doesnt go in and i pushed quiete hard..
Thanks mate
post #6 of 7
Thanks mate
"Been there done that"........so you can use a flash light to shine through the grill cloth......you have already located the holes so line up the logo and tap it in. Don't be afraid,tap it in with a small hammer. I used a wooden crab mallet. The spkr has other holes in case you stand it upright....like if you were using it as a left/right.
post #7 of 7
Ok, and just a question, if i dont use the JUMPERS like i did in the begining, basically i will only get HIGHS and non of the low sound?
And is it possible to not install the jumpers correctly? im asking because i didnt test the speakers yet(my little brother is on the xbox 360 playing so ill leave the calibration and all for tommorow) but from what i can hear the sound coming from the CLR 2002 is kindda low compared to the tower speakers and the surrounds
  Back to Forum: Speakers
