AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Quick question about DVD players
post #1 of 6
Hey, I just bought this 20$ DVD player at walmart "philips DVP642" and I'm just wondering if it gives as good as quality at the 100$ ones, err, like does more expensive ones give better quality? I have a 19" TV lol
post #2 of 6
Well, what do you think?
post #3 of 6
On your 19" TV I don't think you could tell any difference. I thought the Philips was $40 and the small Magnavox was $30. The Philips has the best remote design that I have seen. I'm using one on an old CRT TV so I haven't tried upscaling with it.
post #4 of 6
Yeah I didn't think I'd tell a difference, because my TV can only use component cables, and that's what the DVD player uses, and since it's 19" its 420P lol
post #5 of 6
Is this the TV manufactured by High Times?
post #6 of 6
Actually, you might find this fascinating, a long time ago there use to be this weird technology called "CRT", and they created.. are you ready for this?... SQUARE TELEVISION SETS, yeah I know, that shits messed up isn't it
  Back to Forum: DVD Players (Standard Def)
