AVS › AVS Forum › Audio › Receivers, Amps, and Processors › No sound out of right channel
post #1 of 6
Hi there. I own a onkyo drs2.2 surround sound system. Recently Ive noticed that the right front channel isnt producing sound. I have switched around the cables and speakers to test and they check out. No sound comes from that channel even when doing the speaker test. Im not to knowledgable when it comes to audio equipment and was wondering if someone could help me. Are there specific fuses for each audio channel? Thank you
post #2 of 6
bump
post #3 of 6
Double check the channel level settings, and if they look ok, you may have a blown channel. Likely not worth repairing.
post #4 of 6
any idea how much repairing a blown channel would cost? I never have volume up loud since i live in an apartment so the damage wouldnt be from high volume.
post #5 of 6
I have no clue what your repair cost would be. How much did you pay for this thing and how old is it? I would hazard a guess it's not worth repairing, but that's up to you of course.
post #6 of 6
try this for fuse and channel info -- http://www.user-manuals.com/service-...KYO-DRS22.html
