AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Direct TV dvr to dvd recorder?? Is it possible?
post #1 of 11
I have a HD direct tv dvr and want to get stuff off that onto DVD - can i do that and what type of DVD recorder would i need?
post #2 of 11
Any recorder will work fine (check out the reviews and "official" threads in this forum). Keep in mind they will all record what you playback from the DVR in real time, and it will be in SD, not HD. But high quality SD recordings of HD sources still look very good. I've been archiving stuff from my HR2x over S-video to my Panasonic DVD recorder for a couple of years now.
post #3 of 11
do you have your DVD recorder hooked up in between your tv and dvr or does it go tv, dvr, dvd recorder?
post #4 of 11
I guess it's the latter. Keep your TV/DVR setup as is. Just add S-video/audio out from the DVR to the DVD recorder, and HDMI out from the DVD recorder to your TV (or receiver or switch). DVD recorders don't have HDMI IN, if that's what you were thinking.
post #5 of 11
is here any DVD recorder which has component input? I have panasonic dvd recorder about 3 years old and it has S-video input. when I record SD program from my DVR and replay it on my opo player the quality is not good. I think it is the S-video input which is degrading the quality. Is there some one who can suggest some thing else to get a better recording.
post #6 of 11
Polaroid 2001 has component in, but no longer made.
I have svideo in to my phillips 3575 and quality is fine, so maybe it is your setup. I did have a panny and was not happy with its recording quality compared with the polo, even though it came highly recommended.
I am very happy with the phillips. Record HD (in SD of course) from my directv dvr with good quality.
post #7 of 11
What record quality are you using? I have used XP, SP, and LP all very successfully. I have been told by people who have borrowed my disks that the quality is comparable to purchased DVDs. If you are using EP6 or EP8, that that is most likely your problem. I would stay away from LP quality unless you know in advance that there won't be much fast movement.
You say you are recording with a Panasonic, and playing on an "opo" player. How do they look when played back on the Panasonic?
post #8 of 11
Also if you're recording from a poorer SD source that may have something to do with it. DVDs I've recorded from a good DVD or a WS HD source(downconverted to SD) look as Luke said, like a commercial DVD. Try and not go over 3hrs/disc for programs with much movement. LP will tend to look like a macroblocking mess and even station bugs will have a mosquito effect.
Note if your source is a 16:9 postage stamp and you're using zoom on your TV that will also drastically reduce your PQ.
post #9 of 11
thank you for your response. Sorry I was out and did not get to computer for a while so could not read responses. Anyway, it is the same down graded quality on when I play on panasonic DMR-ES20.
By The way I am recording on LP speed as my movies are more than 2 hours long.
post #10 of 11
Thanks for your response.Sorry I was out and did not get to my computer for more than a week. Anyway, my recordings are in LP as all my movies I record are more than 2 hours. Typically they are 2:30 hours.
As you suspected the source is my Dish network DVR. when I play it directly from PVR it liiks good but when I play though panasonic DVD recorder (without recording), the quality is degraded. That is why I suspect that the S-video connection is the source of degradation.
Any recommendation?
post #11 of 11
They do sell a "component" to S-video adapter but I think it's a little spendy, a little north of $100, but it does have the "advantage" of removing any CP so you'd be able to back up any of your commercial DVDs.
Component outputs(if your STB has them) are probably always full screen and using that along with FR set to 2:30 (instead of the preset speed of LP) should give you much better picture.
There is a thread in this forum talking about the AppleTV S-video converter. The website that sells this devices somehow has Svideo in it's name.
  Back to Forum: DVD Recorders (Standard Def)
