AVS › AVS Forum › Video Components › Home Theater Computers › Add PVR capability to HTPC: Video capture card
post #1 of 7
Hello,
I am building a new system based on the Asus P5Q-EM mATX motherboard. I want to add PVR capability via an internal card, and it appears the AVerMedia AVerTV Combo PCIe is a good choice; I need only PVR not the TV tuner capability, and I'd like this both for capturing external video as well as recording from the HDTV signal. Any other recommendations for a video capture card?
How is it the PVR captures the video signal? Directly through an external cable/video connection or because it is resident in the PCIe slot, software is able to "see" the signal and record it? Is the software Vista Media Center or the supplied AverMedia Software? Thx.
Scott
post #2 of 7
Combo PCI cards such as the Avermedia Combo PCIE and the Hauppauge 1600 or 1800 cards capture analog SD (or downscaled HD) video from a STB analog TV progam input from the analog part of the card usign RF or S-video.
And they can capture OTA HD digital or clear QAM cable HD broadcasts with digital tuner on their cards.
IMHO the Hauppauge are more flexable in what they can do.
post #3 of 7
So if I understand: these combo cards can't take DTV output from a DTV and store it onto a harddrive; rather they capture it over-the-air and store it on the hard drive?
There are cards which capture digital signal from a digital TV or a digital camcorder, am I correct?
If I wanted to watch DTV via a DTV and later record DTV via the Tuner/capture card, then I should split the incoming signal and send it to both my DTV and the tuner/capture card?
Scott
post #4 of 7
As far as I know, there are no consumer HDTVs that output digital video signal. It's got nothing to do with the capture card. Short answer is no.
From a digital TV, no, since the DTV doesn't output digital signal in the first place. From a digital camcorder, don't most of those already use either USB or Firewire? No need to even get a capture card.
Yes.
post #5 of 7
OK...I understand better--thx. I had a vision where a video capture card would accept digital video and then store it on a hard drive. Looks like this doesn't really exist, though over-the-air DTV can be recorded via a tuner/video capture card.
For digital cameras: I need to look and see how they store the video and then transfer it to hard drive. I presume this is stored in a compressed environment and then transferred? And I presume the security cameras still use analog?
post #6 of 7
Sounds like the Hauppauge 1212 HD-PVR is what you are looking for. Check out the owners thread.
post #7 of 7
Yes, the Hauppage 1212 sounds perfect, except that I prefer to have an internal card; I know that doesn't make sense, but I want to reduce the clutter outside the HTPC. Thx for the response.
