Hi everyone,
I've been searching the forum for information but I'm still really confused about what to do in my situation.
My parents live in an apartment building in Brooklyn, New York. They have a standard old SD TV. All these years they have had great reception via a master antennae on top of the building.
I don't want them to get stuck with bad reception. So I went ahead and scheduled Optimum cable to come down and set cable up for them - the basic broadcast package, because that is all they need. I also ordered a HDTV for them since they might as well now take advantage of HDTV.
However now someone is telling me that I am wasting their money and that all they need is a converter box and they should get good reception. But i'm really confused - doesn't using a converter box mean that the HD signal gets transformed in to SD? Basically I would like them to have HD and take advantage of their new HDTV, without having to spend money on cable - is there a way to do that?
I personally tried using an HD antennae in my apartment in Manhattan a couple of months ago and the signal was horrid, i could barely pick up a channel - so i dont want them to go through the same thing.
Anyway I am really very confused, and this is coming from someone who is a total tech geek. Any help would be greatly appreciated
Thank you!
-Terry
Thank you!
-Terry
