AVS › AVS Forum › Audio › DIY Speakers and Subs › Master Index of DIY Subwoofer Projects
Master Index of DIY Subwoofer Projects - Page 4
post #91 of 159
Here is mine: 6.3 cubic ft - 6" ported; 12 Shiva-X
http://www.avsforum.com/avs-vb/showthread.php?t=1148326
Usil
post #92 of 159
nice work usil. added!
post #93 of 159
Please append my Tuba HT (THT) build thread that can be found on BFM's forums here: http://billfitzmaurice.info/forum/vi...php?f=5&t=8589
post #94 of 159
cool. i linked that as 1 and your avs as 2 in the master index. if it should be presented some other way, just let me know and i'll change it up. the master index belongs to us all. i'm just the keeper for now.
post #95 of 159
what is preferred sealed or ported design?
post #96 of 159
welcome to avs jaco. the answer is it depends. lots of discussions around here for identifying the variables. ;-)
post #97 of 159
I think it would be benefical to group all the Tuba Home Theater subwoofer build threads together when you get a chance? Thanx!
post #98 of 159
i suppose the list is getting large enough that segmenting it might make some sense. given that everybody will want to carve it up in different ways, i'm still noodling what makes the most sense. maybe i will just breakout all horns as a first, very rough, sort that most everyone could agree with. it seems stupid that such a trivial database sorting app hasn't found its way into discussion fora yet, oh well, i'll see what i can do.
post #99 of 159
sealed, ported, horns?
post #100 of 159
the problem is that everybody will want a different cut.
some will want size.
some will want cost.
some will want efficiency.
some will want extension.
some will want max spl at single hz.
some will want max spl at teens hz.
some will want max spl at 20hz.
some will want a specific design (sealed/ported/horn).
and so on.
given that there are a boatload of ways of "slicing and dicing" the builds, i'm not really sure that it makes sense to try to sort them. i suppose some sort of cluster analysis might work, but that seems like overkill for what i had in mind here.
i'll noodle your comments.
post #101 of 159
Wouldn't some form of organization be better than none?
Yeah I know its alphabetical, but that does no good when the sort starts with user names, first names, "THE", thread topics, driver model #s, subwoofer pet names, ect.
Makes most sense to me to organize by alignment, as this is most DIYer's fork in the road to make comparisons on.
Just my 2 cents, hope it helps!
Dr V
post #102 of 159
after noodling it hard, i don't think any ordering makes sense.
the reason is that any person can make an equally valid rationale for another sort.
for example, should horn subs be grouped with their efficiency counterparts, their cost counterparts, or their response counterparts?
this kind of argument grouping / comparisons is without end.
everybody will have a different (and valid) opinion.
maybe it would be best to tag each build so that it can be easily sorted by users.
if someone wants to pull out all the tht builds that should be easy, even though at the moment it is impossible.
let me noodle that for a while. i see where you are coming from.
ten years from now, we will look back on this problem and laugh...
post #103 of 159
price and difficulty come to mind.
and/or maybe driver/enclosure size since thats a good comparison.
the size one would help with "approval factor"
But for now a decent description helps.
maybe change the links to just the names then add a sentence or two after for a summary.
just a few ideas
post #104 of 159
hometheatershack has a nice way of slicin and dicin
http://www.hometheatershack.com/foru...-database.html
post #105 of 159
Which of these come with the kit and has all the pre cuts for the box and is under $500, I have never diy a sub before so I want something easy to start off with and I guess I am never going to learn if I don't try right lol?
post #106 of 159
more research required supermoore1025...
post #107 of 159
post #108 of 159
thanks stgdz, added!
post #109 of 159
post #110 of 159
added! i try to keep up with all the builds, but alas i can't. i was thinking of asking for new builds every six months or so. you beat me to it.
post #111 of 159
I like this idea for sub arrangement. You select a driver and have all of the different possibilities using that driver listed together. This would not be the greatest for a person that wanted to look at only THTs for example, but it is great for those that already have drivers and want to look at other possibilities. Also great for those that come across a good deal on a driver and want to know what they can do with it. Might need both though. Theater Shack is set up this way, Driver based and configuration based. Makes for extra work on your end, but it is nice for searching through.
post #112 of 159
Great thread. When do I get added?
post #113 of 159
gmichael2, i've been lurking during your amazing build thread...i should have added it earlier...awesome stuff...added!
post #114 of 159
You need a Maelstrom 21" in here (see signature)
post #115 of 159
corock, added! now, you have to actually finish it. ;-)
post #116 of 159
I'm not sure I remember what life is like without having this build. Besides, do I have the record for the longest time to build a subwoofer yet?
post #117 of 159
Thanks. I'll try to have it finished in the next week or two. It's been a long build, but not as long as corock's. (It was his build that started on another site that inspired my build)
post #118 of 159
roger that gmichael, i've never been one to nudge folks, but a midrange egg actually holds much more potential than a bass egg. don't we all love mother nature and what she can do off axis? ;-)
post #119 of 159
I think mine are ready to be added to this list!!
http://www.avsforum.com/avs-vb/showthread.php?t=1233892
post #120 of 159
i'm sorry for not including your build...added!
