Hi,
I have just about had it with Harmony support.
Is there some way to get to Level 2 or Engineering Level Support???
I have a H550 and I know it is not the top of the line, but I was assured that it more than meets my needs.
It cannot even properly send a discrete command during power on without waiting 28 seconds! or to select the device manually and selet the input. If I am lucky I can do that in 10 seconds.
I can tell you none of my devices take longer than 8 seconds to accept a remote signal after power on. My original remote can do it within 7 seconds. Though I have 4 remotes for my devices to power on, I now only need two remotes to do the trick.
Until my issue gets resolved soon, I cannot recommend Harmony at all.
