Originally Posted by
shepP
No sequences? I have the 1000 and thought I was using sequences when I click on an activity.
An example of a sequence would be steps you must go through with the factory remote for you TV to turn on High Brightness Mode. You would create a sequence stating to select "Menu", "Down Arrow", "Down Arrow", "Enter", "Select". This would mean, open the menu on the TV, go down the menu twice, press enter on the highlighted option, use select to choose High Brightness. You could call this sequence "Hi Bright" and use a button on the remote to automatically do it.
An Activity example would be Play a Game on Xbox:
1: Turn on TV, choose input HDMI
2. Turn on receiver, choose input HDMI2
3. Turn on Xbox 360
You could then use a hard button for example like "Previous" and attach the Hi Bright Sequence to it so the TV would be bright and beautiful.
I know its confusing.
