Originally Posted by darinp2
I measured the center 4 boxes from a Samsung A800B at 127:1 the other day (after pretty much eliminating the room), yet with a resolution pattern of small amounts of white on black there was little to no chromatic aberration, even in one of the far corners I was checking out. It was very sharp at the pixel level. I'm guessing this thing would have higher MTF at full resolution than the Sony VW80, even though the VW80 had more ANSI CR than it (I measured the VW80 at about 400:1 ANSI CR and on the ANSI CR pattern the VW80 looked like it had brighter whites and darker blacks than this DLP). Unfortunately I didn't get a chance to compare real material between the two or really check things out on that front (we were testing temporal resolution kinds of things with the dark frame insertion, etc.).
Even misconvergence between the panels with a 3 chipper will hurt MTF for white at full resolution, but should have little to no effect on ANSI CR. And LCOS (at least the DILA version) seems to have its own issues with single pixel things like a 1x1 checkerboard that likely have little to do with the ANSI CR pattern.
I can't recall a case of such low ANSI CR, yet single pixel things that made it look like the lens was very high quality. I think there does tend to be quite a bit of correlation, but there are likely exceptions and this A800B would be an interesting one to investigate further. I'm hoping to get to see another A800B and check its ANSI CR, then maybe do some comparisons with content, or get a chance to view this A800B some more.
I know LCD wasn't mentioned, but the Panasonic AE3000 has been measured with pretty good ANSI CR (I believe 300:1 to 400:1 depending on mode and who is measuring) and I'm not sure that means it has MFT at full resolution that is relatively as good. Although it might be high compared to CRT.
--Darin
--Darin
Yes exactly. I think that the notion of MTF correlating with ANSI has been made mostly because it's been happenstance that some technologies like DLP that have high ANSI contrast also have high MTF. Both measures are probably independent from each other. In fact if we look at a plot of MTF % vs frequency (say line pair/mm) it's hard to equate a point on that curve with the ANSI pattern because contrast measurements from that pattern are unique to that pattern. But if we make the leap that it may be roughly similar to a low frequency MTF pattern, the corresponding MTF anywhere at those low frequencies will be very close to 1 for every type of native 1080p display. In other words there isn't a way to infer ANSI contrast from the MTF curve. Working it from the opposite direction (trying to infer MTF from ANSI) is also difficult because there are so many 3-panel and lens issues (mainly convergence, CA and focus) which don't play much of a role in ANSI contrast but play huge roles in MTF.
As you've pointed out it's easy to mess up the MTF of a 3-panel by unfocusing or misconverging the lens but the ANSI cr is unchanged. As another example of this, my old RS1 had about 1/2 of a pixel of misconvergence and some red CA, but my RS20 has excellent convergence, low CA and is strikingly sharp compared to my RS1. The combination of sharpness and improved on/off gives the image a sharper and crisper image which is noticeable even with mixed scenes. It was mainly because of the crispness in mixed scenes that I was expecting ANSI to be significantly improved, but when I measured ANSI it is down on the RS20 compared to the RS1. Mlang a retired optics engineer and forum member, also made this same assumption at Cedia (that the RS20 had higher ANSI) and was also surpised to see that this wasn't the case.
At any rate, I think that what's happened is that there has been a dearth of MTF data and as a community we've maybe made some seemingly sound assumptions in the absence of this data that probably doesn't really hold water. It's too bad that reviewers don't perform MTF measurements as part of their reviews, but given the variance of 3-chippers that can cause huge differences in MTF, I'll bet that there is some reluctance by reviewers to publish these sorts of tests and probably a reluctance by manufacturers to allow the reviewers to make the measurements in the first place. Even ignoring variances between units, there's probably a large variance of MTF within the field of a given unit.
from Speed racer. Superb detail at 14 ft
