I finally got this put together. My main goal was to have an analog path as well as a 7.1 digital path. I've been happy with the audio quality. Video's not bad either...
Paradigm Reference Studio 60 v.4 fronts, CC-590 v.4 center, ADP-590 v.4 sides, ADP-470 v.3 backs, PS-1200 sub
2 x Monster PowerCenter HTS 3500
Amps: Emotiva XPA-5 (200wpc) and XPA-2 (250wpc)
Preamps: Emotiva RSP-2 (analog), Onkyo PR-SC885 (digital, 192/24), PA 928 flat phono (for pre-RIAA 78s)
Omaura cased HTPC with HDHomerun QAM box. PC runs digital into Onkyo and analog stereo into Emotiva.
Vestax BDT-2500 turntable goes through RSP-2 to XPA-2 with XLR cables for a straight analog connection or into the pc for recording.
Sony KDL-52XBR4 tv
PS3 (60GB), Wii, Sony BDP-S350 bluray
Denon 955S(2910) dvd for SACD (DSD Direct via analog out to Onkyo) or DVD-A (HDMI to Onkyo)
Sony KDL-52XBR4 tv
It's nothing like the 'my little setup' thread, but I do what I can. The racks are Omnimount. I should've mentioned that. I was in a bit of a hurry earlier. Didn't even get the plastic off the RSP-2! I'm much more a reader than a poster. I should have also mentioned that AVS Forum has been a great help to me. A lot of calibration help and also where I discovered a lot of these components. I couldn't give enough thanks for having a source like this.
My gf is obsessed with buns. It was only a matter of time before we had some. They're cute and fun. Not bad to have around.
I've been on that quest for quite some time now. It's been at least two weeks now and I'm still not finished.
With a three rack setup, it bordering on impossible to achieve perfect wire management. You can come close if you have the right cable lengths and proper positioning of the components and of course, the racks have to be able to accommodate the cables. What I like about your equipment positioning is the fact that your power centers are on the outboard racks. Unfortunately, mine are currently positioned on the TV rack. It looks cool, but makes it difficult to have complete separation of the power cords and audio/video cables. I will eventually move the power centers to the two audio racks because a multi-channel amp will reside in the space the power centers will leave vacant.
