Hello fellow plasma owners!
I've created a new set of plasma break-in images (with all due respect to Evangelos Angelides). They are intended to be put on a memory device, such as an SD card or USB/flash/thumb drive, and used as a "slideshow". If your plasma TV has no slideshow function, I suppose you could burn the images to a DVD if you know how, but you're on your own if you want to do that.
There are 3 sets in all, and you can use one, two, or all 3 of them if you so choose. If you want to use more than one set of images, I suggest you put them on separate memory devices or else some of the files will overwrite one another (because some of the file names are shared).
The only favor I ask is that you share the link to my web page, rather than sharing the files themselves. That way I can track how many people are downloading the files, and if the interest is high enough and the feedback is positive (i.e. the images work!), then I will continue to invest the time to improve upon them.
Thanks! Here's the link:
http://www.webapalooza.com/plasma/
and run it non-stop for hundreds of hours... I think not.
