Code:
Total Video
Title Codec Length Movie Size Disc Size Bitrate Bitrate Main Audio Track Secondary Audio Track
00000.MPLS AVC 2:43:05 32,534,206,464 49,322,486,710 26.60 23.01 DTS-HD Master 2.0 1908Kbps (48kHz/24-bit)
DISC INFO:
Disc Title: LAST_EMPEROR
Disc Size: 49,322,486,710 bytes
Protection: AACS
BD-Java: Yes
BDInfo: 0.5.1
PLAYLIST REPORT:
Length: 2:43:05 (h:m:s)
Total Bitrate: 26.60 Mbps
Description:
VIDEO:
Codec Bitrate Description
MPEG-4 AVC Video 23008 kbps 1080p / 23.976 fps / 16:9 / High Profile 4.1
AUDIO:
Codec Language Bitrate Description
DTS-HD Master Audio English 1908 kbps 2.0 / 48 kHz / 1908 kbps / 24-bit (DTS Core: 2.0 / 48 kHz / 1509 kbps / 24-bit)
Dolby Digital Audio English 224 kbps 2.0 / 48 kHz / 224 kbps / Dolby Surround
SUBTITLES:
Presentation Graphics English 36.668 kbps
FILES:
Name Time In Length Size Total Bitrate
00000.M2TS 0:00:00.000 1:55:06.858 22,904,401,920 26,529
00001.M2TS 1:55:06.858 0:47:58.917 9,629,804,544 26,760
CHAPTERS:
Number Time In Length Avg Video Rate Max 1-Sec Rate Max 1-Sec Time Max 5-Sec Rate Max 5-Sec Time Max 10Sec Rate Max 10Sec Time Avg Frame Size Max Frame Size Max Frame Time
1 0:00:00.000 0:06:48.116 14,696 kbps 28,254 kbps 00:04:00.114 27,531 kbps 00:04:00.114 24,696 kbps 00:03:56.903 76,611 bytes 233,629 bytes 00:00:08.007
2 0:06:48.116 0:08:04.442 21,992 kbps 38,314 kbps 00:11:01.035 32,301 kbps 00:11:00.951 30,317 kbps 00:10:33.007 114,659 bytes 289,988 bytes 00:10:42.933
3 0:14:52.558 0:03:42.513 23,790 kbps 36,673 kbps 00:16:26.402 32,951 kbps 00:16:34.868 29,218 kbps 00:15:38.020 124,031 bytes 350,876 bytes 00:15:04.862
4 0:18:35.072 0:02:43.454 21,506 kbps 31,224 kbps 00:20:38.028 26,459 kbps 00:19:31.378 26,282 kbps 00:19:31.003 112,125 bytes 214,109 bytes 00:21:14.940
5 0:21:18.527 0:02:07.001 18,991 kbps 25,130 kbps 00:23:23.860 23,845 kbps 00:22:27.721 22,409 kbps 00:22:26.094 99,012 bytes 234,604 bytes 00:22:29.890
6 0:23:25.529 0:09:08.047 26,763 kbps 39,676 kbps 00:26:48.815 36,860 kbps 00:26:44.811 36,376 kbps 00:26:39.806 139,533 bytes 293,510 bytes 00:26:11.903
7 0:32:33.576 0:04:39.320 24,718 kbps 38,130 kbps 00:33:17.578 36,290 kbps 00:33:17.328 35,077 kbps 00:33:12.448 128,869 bytes 288,377 bytes 00:33:11.114
8 0:37:12.897 0:04:34.607 24,569 kbps 35,273 kbps 00:41:12.845 34,326 kbps 00:41:12.720 33,048 kbps 00:41:10.009 128,092 bytes 274,815 bytes 00:40:00.815
9 0:41:47.505 0:03:53.233 22,173 kbps 37,192 kbps 00:42:01.519 35,192 kbps 00:42:30.547 34,938 kbps 00:42:30.130 115,599 bytes 237,668 bytes 00:41:59.850
10 0:45:40.738 0:04:11.084 25,239 kbps 36,797 kbps 00:47:57.457 36,360 kbps 00:47:51.451 36,178 kbps 00:47:49.283 131,585 bytes 313,311 bytes 00:47:54.913
11 0:49:51.822 0:07:20.273 27,030 kbps 40,247 kbps 00:51:08.940 36,405 kbps 00:50:56.136 36,221 kbps 00:51:41.932 140,923 bytes 283,457 bytes 00:55:54.017
12 0:57:12.095 0:03:19.032 20,826 kbps 28,783 kbps 00:58:18.703 27,520 kbps 00:58:18.703 25,946 kbps 00:58:16.659 108,579 bytes 213,854 bytes 00:57:41.666
13 1:00:31.127 0:04:29.769 24,318 kbps 33,416 kbps 01:01:10.917 32,200 kbps 01:02:49.015 31,797 kbps 01:02:47.138 126,784 bytes 306,956 bytes 01:01:10.958
14 1:05:00.897 0:05:30.413 21,300 kbps 30,838 kbps 01:09:33.043 27,472 kbps 01:09:29.623 27,057 kbps 01:09:40.676 111,050 bytes 265,662 bytes 01:06:50.631
15 1:10:31.310 0:03:01.556 23,515 kbps 35,429 kbps 01:10:31.727 31,103 kbps 01:10:31.310 27,560 kbps 01:10:31.310 122,596 bytes 216,176 bytes 01:12:43.609
16 1:13:32.866 0:08:23.044 21,880 kbps 37,226 kbps 01:19:10.036 36,199 kbps 01:20:43.713 32,646 kbps 01:19:04.364 114,074 bytes 288,250 bytes 01:20:34.788
17 1:21:55.911 0:06:15.708 23,098 kbps 36,906 kbps 01:22:57.389 34,055 kbps 01:22:56.721 33,654 kbps 01:22:56.721 120,425 bytes 470,538 bytes 01:22:56.763
18 1:28:11.619 0:06:48.157 22,818 kbps 35,641 kbps 01:29:19.020 33,438 kbps 01:28:40.023 33,095 kbps 01:28:40.106 118,962 bytes 220,232 bytes 01:31:56.344
19 1:34:59.777 0:08:01.230 19,591 kbps 30,600 kbps 01:37:25.923 27,847 kbps 01:37:25.881 27,163 kbps 01:37:25.881 102,139 bytes 209,287 bytes 01:37:26.924
20 1:43:01.008 0:04:10.124 24,371 kbps 35,396 kbps 01:46:29.424 34,721 kbps 01:46:25.545 32,281 kbps 01:44:21.421 127,058 bytes 240,661 bytes 01:46:27.714
21 1:47:11.133 0:06:02.487 27,027 kbps 37,793 kbps 01:52:30.452 36,292 kbps 01:51:49.786 36,247 kbps 01:51:49.661 140,909 bytes 302,931 bytes 01:51:26.513
22 1:53:13.620 0:09:06.504 21,921 kbps 33,472 kbps 01:54:15.807 31,737 kbps 01:54:12.178 30,830 kbps 01:54:07.257 114,286 bytes 217,829 bytes 01:54:07.590
23 2:02:20.124 0:02:48.501 23,479 kbps 32,513 kbps 02:04:51.650 31,547 kbps 02:04:51.692 29,741 kbps 02:04:51.650 122,410 bytes 197,620 bytes 02:05:08.000
24 2:05:08.626 0:07:54.432 23,264 kbps 35,287 kbps 02:05:30.981 34,020 kbps 02:05:30.356 33,150 kbps 02:05:28.187 121,287 bytes 263,590 bytes 02:05:36.946
25 2:13:03.058 0:05:04.762 23,549 kbps 34,524 kbps 02:16:44.696 33,465 kbps 02:16:50.911 32,822 kbps 02:16:45.196 122,771 bytes 245,002 bytes 02:13:15.654
26 2:18:07.821 0:07:17.562 23,254 kbps 37,558 kbps 02:22:56.109 35,952 kbps 02:22:52.313 35,655 kbps 02:22:47.517 121,235 bytes 232,495 bytes 02:22:56.859
27 2:25:25.383 0:03:25.413 25,883 kbps 37,561 kbps 02:26:55.223 36,058 kbps 02:26:51.219 35,667 kbps 02:26:47.465 134,940 bytes 273,577 bytes 02:26:35.620
28 2:28:50.796 0:05:51.267 26,262 kbps 37,070 kbps 02:31:37.046 35,995 kbps 02:31:36.545 35,006 kbps 02:31:33.793 136,919 bytes 299,142 bytes 02:32:36.438
29 2:34:42.064 0:08:23.711 20,561 kbps 40,837 kbps 02:37:32.276 36,972 kbps 02:37:28.272 36,413 kbps 02:37:23.267 107,205 bytes 385,585 bytes 02:37:32.609
STREAM DIAGNOSTICS:
File PID Type Codec Language Seconds Bitrate Bytes Packets
00000.M2TS 4113 (0x1011) 0x1B AVC 6906.733 23,000 19,856,583,206 108,012,553
00000.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 6906.733 1,844 1,592,049,576 9,782,135
00000.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 6906.733 224 193,392,640 1,079,200
00000.M2TS 4608 (0x1200) 0x90 PGS eng (English) 6906.733 39 33,359,324 188,466
00001.M2TS 4113 (0x1011) 0x1B AVC 2878.834 23,031 8,287,904,443 45,083,714
00001.M2TS 4352 (0x1100) 0x86 DTS-HD MA eng (English) 2878.834 2,061 741,544,348 4,460,462
00001.M2TS 4353 (0x1101) 0x81 AC3 eng (English) 2878.834 224 80,610,432 449,835
00001.M2TS 4608 (0x1200) 0x90 PGS eng (English) 2878.834 32 11,493,374 64,775
