I realize there's a somewhat similar thread going on, but please bear with me and give me your advice.
I have an XG110LC that was setup by Chuchuf (Terry) with a 720p72 signal input. It looks great with the MPEG2 HD stuff I've been viewing for several years.
I just put together a new Blu-ray capable HTPC. Using the very same signal input, still out the VGA port to 5BNC, it looks absolutely incredible. I really can't imagine it looking any better than it does now, and I'm very picky (although of course I have no reference for comparison).
I don't really want to have to spend the money on a Moome card to go HDMI, but I had envisioned sticking with the VGA out, and changing the HTPC's output to 1080i72 or 1080i96, based on what I've read on this forum (it seems that 1080p would be pushing it for the XG).
If it were easy to try those out and see, I would...but I'm running into (an apparently common) issue of my nVidia drivers rejecting these custom resolutions. Even if I manage to put in the hours to troubleshoot this, I don't know whether I'll be able to converge the new resolution/refresh as well as my current one is setup.
So, I'm asking you to play devil's advocate and convince me that it will definitely be worth the considerable hassle to get another signal going here. Will I see better detail on wide shots? Will there be better motion?
It does seem ridiculous that I'm viewing 1080p Blu-ray material at 720p, but it looks phenomenal....I just need to know (in words) what I might be missing here.
Brent
Brent
. It synced fine but I was getting wavy lines from the test pattern and gave up. I did try it before at the proper 48hz interlaced (for 96) and it did look very good. More stable flicker-wise, just as 72hz is more stable than 60 and 48hz. Even with a crude setup it looked better than my well tweaked 1280x720 72hz setup. But I couldn't be bothered to do the 1080 96 setup as 720 looked pretty good still.
