AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Pioneer Pro1150hd Light blinking
post #1 of 5
I have Pro 1150HD and last night turn on my Tv and it went from red light to blue light blinking 12 times then stop blinking 12 and stop. no picture. So I turn off the tv with remote turn it back again and it works fine. Dose anyone knows what it is?
post #2 of 5
I have read several threads dealing with this same problem. I don't remember what exactly it was but doing a search will bring them up.
Hope things work out.
post #3 of 5
Something related to an error in receiving the latest updates from the tuner. If you are not using the built in tuner, you should set your zip code to 00000, which should disable this completely.
post #4 of 5
Cool I tough my Tv is going crazy. That is wierd that tv wont turn on it will just flash that code till you turn it and and off again. I will channge the zip. Thank you.
post #5 of 5
I have the 1130, and I believe the blinking blue lights (in 12 blink intervals) is your TVGuide attempting to update, but unsuccessful.
If you don't use the TVGuide, then changing the postal code would work (as I've read on this forum). If you do use the TVGuide, then you may want to enter your postal code and give it another shot.
