been reading a bunch here and learned a lot...enough to have a plan even! however, i would appreciate a reality check...and maybe even a slap in the head (
) if i've missed/misinterpreted anything.
here's the relevant equipment / details:
so the obvious answer (at least to me) would appear to be a standalone sub. no, i'm not sure which one yet. leading contenders are the SVS PB12-NSD and the hsu VTF3.3. in any case, my dilemma is how to best integrate a true sub with the def tech pseudo-subs.
current receiver settings (pre-standalone sub)
there are also sub level controls on the speakers themselves...set to def techs recommendations (1 o'clock mains, 2 o'clock center...whatever that means), so as to provide a constant there, with all tuning done at the receiver. speakers are currently connected using both speaker-level and LFE inputs, making the receiver x-over setting largely irrelevant i guess.
so, gory detail behind us...
my plan is to move the receiver subwoofer output away from the fronts and connect it only to the true sub, using the receiver x-over to cut out the lows sent to the front stage. my thinking is that this will let the 8" 'subs' up there function more as mid-bass. i'm not sure where the x-over is between the (small) midrange drivers and the 8" 'subs', and i want to make sure the 8" have something to do! i envision the true sub located near field, with no corner loading.
other than the connection change, the only other change i see is in the receiver x-over frequency. def tech recommends a 'fairly low' x-over setting...40-50hz. my choices are 40 or 60. i realize there are slopes, but where would that 40-60hz info be better realized...at the 12" big hitter or the 8"? again, def tech says they're flat to 33hz, and i believe the x-over to the mids is ~80hz (which seems awfully low for the 12cm mid drivers).
obviously, the entire setup will be recalibrated w/avia once the changes are in place.
final question...how about the LFE level setting? i see in the sticky that this channel is designed to be boosted by 10db and should be handled correctly by the receiver's decoder. so that means set at 0db on my system...calibrate there and leave it there?
thanks for any/all input, and phew...sorry to ramble!
) if i've missed/misinterpreted anything.here's the relevant equipment / details:
- yamaha rx-v2600 (output labeled as 'subwoofer', menu adjustments refer to 'LFE' and 'subwoofer' separately)
- def tech bp2006tl mains (8" x 250w integrated 'sub', 4.75" mids, def tech says flat response to 33hz, have both speaker level and LFE inputs...internal x-over sums the lows from both inputs)
- def tech clr2300 center (same driver arrangement, no LFE in)
- all sources output digital bitstream (via HDMI and S/PDIF coax) to receiver, which handles all decoding
- 'large' fronts & center
- 'bass out' to subwoofer (other choices are 'both' and 'front')
- 80hz 'bass x-over' (choices 40/60/80/90/100/110/120/160/200hz)
- normal sub phase
- 0db 'LFE level' (range is -20db - 0db)
- there is also a 'subwoofer speaker level' adjustment (-10db - +10db) that was set using avia and an SPL meter
