AVS › AVS Forum › Audio › Speakers › Triad inwall Gold/6 5.1 setup question
post #1 of 7
i want to get 3 Triad inwall gold/6s up front, but for the surrounds will i be giving up too much by going with (2) Triad inwall silver/6's?
the gold/6 in walls have just too big of a grill for my wife (40x14).
any creative way to hide some of the speaker grill (besides painting it flush)?
post #2 of 7
I don't see a problem with going with the Silver surrounds at all.
Jump over to our Triad thread for further clarification and advice. http://www.avsforum.com/avs-vb/showt...+owners+thread
post #3 of 7
Tony is correct.
And you don't have to paint the surrounds. We match the paint for free.
If you're speaking about our Surrounds, the InWall Silver/4 Surround is used quite often with Gold LCRs, or even Gold Monitors. No problemo...
post #4 of 7
but ideally 5 inwall gold/6 would be best for timber matching no?
am i giving up anything by going with the silver/6 for surrounds?
roughly, what are the gold/6's and silver/6's inwall list price per pair?
thanks again,
audio newb.
post #5 of 7
Yes, something can be said for having all 5 speakers being the same. However, rear surrounds are not nearly as important as the L/C/R being identical.
Making your wife happy is always a good thing.
post #6 of 7
thanks again,
audio newb.
If you have a live room that's fairly big, go with dipoles. If the room is well treated and/or smaller, and you have limited seating, go with direct-radiating. Five identical speakers work great unless you have a small, dead room with lots of seats, and then they "hot spot."
The InWall Silver/4 Surround is $800 each. The InWall Gold/4 Surround is $1,600. The InWall Gold/6 LCR is $2,150 each. The "/6" designation indicates the minimum stud space required for installation.
post #7 of 7
I am looking for the set.
Best price pls?
  Back to Forum: Speakers
