AVS › AVS Forum › Display Devices › Direct View (single tube) CRT Displays › Minimum speaker distance from 36 inch CRT HDTV?
post #1 of 2
Hey everyone, I have a 36 inch CRT HDTV (Sony KD-36XS955) with a couple of Polk bookshelf speakers connected through a separate receiver. The speakers are mounted 2 feet away from the TV on each side. Is that too close to the TV? The speakers have a bit of noise going through them and I live in an older house with wonky aluminum wiring so I'm just trying to narrow down the cause of the noise.
Any and all suggestions are welcome!
post #2 of 2
No, the TV shouldn't be the cause. If the speakers were positioned too close you would've gotten color distortion on the TV because of the magnets, but i don't think the set could cause noise in the speakers.
