Hi,
I am new to high-end remotes and after doing a little research in the forums would like to get an RF capable remote.
Right now I am using a Phillips uninversal remote ($20) from Best Buy. So you know were I am coming from. The thing I like about this remote is I programmed it once two years ago and have not had to mess with it since.
My home theater is done now and my componants are in thier own room. Im tired of keeping the door open and leaning just right to use the remote from the couch. Not too impressive when the friends come over.
So far, I have the MX-810 and the Harmony 890 on my short list. It apears from my reading that the 810 might a better built product but a bit more complicated to set up when compared to the 890. Can anyone confirm this?
My original budget was $200- but that seems like it is not going to happen. The 890 is around $250 and the 810 with an RF sensor is about $400? Are there any other serious offerings in that range?
The two things I fear most is having a remote that wont stand up to my four kids daily usage, and one that is not very stable (requires constand fiddling to keep working perfectly. ie syncing and such).
I dont mind spending a good portion of time setting up the remote, but once set up I am not the type who derives pleasure from constant reprogramming.
Can anyone chime in with pros and cons to both of these remotes? I need a bit more info to sway one way. Of course if there is a remote I have neglected to add to the list, please let me know as well.
Kent
Kent
