Well.... originally I was going to work on a MythTV box. That is on the back burner and now I am looking at the best way to connect my laptop, having modeline issues with HDMI, but S-video works ... but back to this thread....
If I am going to buy the SK-7500 I will now need a ps/2 to usb adapter to connect to the laptop. As mentioned earlier in this thread there are some issues with the cheap adapters but not sure I am willing to pay twice the price for an adapter then the keyboard
So I did a bit of searching and I may have figured out why the lower cost adapters work and the higher cost ones do. Looks like the lower cost adapters only connect the wires to the change the physical connection while the more expensive ones have a chip doing some processing. -- **edit** -- looks like RGB was right about the current draw. Answer Q&A number five also mentions current draw!
See link http://www.clickykeyboards.com/index...id/0/id/179740 (second question and answer)
So by that theory something like the StarTech USB2PS2 should work and can be found for a bit cheaper then y-mouse. Also the converter listed second (part #USB-PS2) on this page should also work.
***EDIT***
I think I found the adapter listed here for sale cheaper here, here, here, and here $7.47 is the cheapest
(plus shipping)
The ziotek website is here
***END EDIT ***
What do you think? Could that explain why the cheap converters don't work and why the Y-mouse does?
***EDIT***
(plus shipping)The ziotek website is here
***END EDIT ***
but hope to this by this fall
