Originally Posted by
ninthdragon
I trust Kevin Miller (a founding member of the ISF and a member of this forum) to calibrate the LV to
his standards. I am sure that when he tells me I am "good to go", I'll have no complaints. I believe the LV will set the bar fairly high for image quality, but that, however, remains to be seen. Let's just say I'm a glass half full kind of person. Let's all hope that this tale will be (well) told in six or eight weeks.
So now we have REC 601, REC 709 and Kevin Miller 001 - nice
I wonder how Joel Silver would feel about that.
I suspect that Kevin Miller would tell you that he would calibrate it to REC 709, which again, would eliminate the wide gamut and incorrect colors, which are the qualities you have stated in your previous posts that you like.
So again, if you want wider color gamut with incorrect colors, including the green that is off the scale, there are much cheaper sets that will give you that. If you want a set that displays correct REC 709 color points, there are also cheaper sets.
