Originally Posted by
spoiler1041
Can media be streamed to this TV from a pc or smart phone with out going through a device like xbox?
spoiler1041
I also don't see if this is THX certified?
I'd also like to know if you only wanted to spend $2,500 on a TV, is this picture so striking I should find another $2,000 and buy it?
The L75-A91 has a wired LAN input only, so without first hardwiring the set to another device (like an Xbox) with Wi-Fi, you can't stream content to the television wirelessly. Also, any media you stream through your Xbox must be on a device that supports Windows Media Player or Zune software (or, you can use a conversion tool like RealPlayer SP, Nero Move It, Format Factory or DoubleTwist on Flash-based videos, iTunes and other non-Windows-based content).
Here is a quick explanation of how to do so. You didn't specify whether you have an older Xbox, which requires a wireless USB adapter, or one of the new models, released last year, which feature integrated wireless. The explanation at the above link is for older Xbox models. Obviously, with the newer Xboxes, you can skip the part about installing the wireless USB adapter.
Here and
here are links to further information on this topic.
The new L75-A94 has built-in wireless, so as long as your devices have Wi-Fi enabled they should be discoverable by the TV via your home network. Mitsubishi normally doesn't pay to get their sets THX-certified, but you will find that both LaserVue models meet or exceed those performance requirements. Value, like beauty, is in the eye of the beholder. I wouldn't spend the rent money or take it out of your retirement account to buy this set, but if you can afford it, it's likely you will not be disappointed.
