I tried different distances up to 1 foot, and I found that the distance only moved the peaks and nulls around, it didn't reduce them. I don't know enough about the physics behind comb filtering to discuss this though, only report what I found. Those measurements were with the screen roughly 12" from the source, but as I said, putting it closer or even farther had minimal effect on reducing or increasing the shear size of the peaks and nulls, and mostly just moved them around a little.
Acoustic phase is key in understanding whats going on here. I didn't post it because most people don't really understand it, but if there is interest, I can post those as well. You see drastic flip/flops added to the phase response which directly correlate to the response anomalies. As I understand it comb filtering is a function of the sound waves at different frequencies arriving at the "destination" at different times, attenuating and enhancing the frequencies in the "comb" shape. If moving the material farther away could reduce comb filtering, it needs to show up in the phase (our proxy indicator of time differences) and it didn't stop the effect, it just moved it around, which is exactly as I would expect. It really makes no sense to me that moving the mesh farther away would change that, but as I said, I just don't know enough about the subject to discuss it extensively.
, I'll run this by my wife.
