AVS › AVS Forum › A/V Control & Automation › Tweaks and Do-It-Yourself › DIY rca to mini-jack
post #1 of 7
i want to make my own 50ft length cable to hook up my computer to my 2-channel amp in my woodshop. can anyone provide a wiring diagram for the mini-jack end?
thanks
lewis
post #2 of 7
Tip = Left
Ring = Right
Sleeve = Ground
http://en.wikipedia.org/wiki/TRS_connector
post #3 of 7
You can also just buy an adapter very cheaply.
post #4 of 7
Here is a wiring diagram.
post #5 of 7
dude, buy an adaptor. cost you $5. tops.
post #6 of 7
The (cheap) adapter only has one of the ground wires connected, leaving the other gnd wire on the RCA cable open. Is this a problem?
post #7 of 7
Is this a problem?
No, ground is common to both channels.
  Back to Forum: Tweaks and Do-It-Yourself
