AVS › AVS Forum › HDTV › HDTV Recorders › Moxi 3012 DVR Q&A and Discussion Thread
Moxi 3012 DVR Q&A and Discussion Thread - Page 2
post #31 of 401
Originally Posted by Tobias Ziegler View Post
Open question to anyone with a new 3012 Moxi:
Can the Moxi send out an HD signal (720p or 1080i) on its component output while at the same time sending out an SD version of the same content on the S-Vid and composite outputs?
I'd like to be able to have HD content showing at HD resolution on a TV adjacent to the moxi while at the same time have the same program (in down-rez'd form) sent to another TV located in a different room.
With my old moxi, I have to set the Moxi to output only 480i signals for all programming in order to view HD programs in my second room. This is a nuisance when I want to view the programming in HD on the TV connected via component.
The HD tuner I had four years ago was capable of doing what I wanted, but I lost that ability when I "upgraded" to a Moxi. Can anyone tell me if my desire will be met with the new Moxi?
Thank you.
Well got home early today and hooked up a second video source via RCA. Same as before, you have to turn off all other resolutions except for 480i. Sorry folks. I tried both HDMI and Component with the same results. If anything other than 480i is checked, I still get audio but the second (SD) screen goes gray.
post #32 of 401
Originally Posted by jkramer View Post
I can confirm the internal drive is 160 gig drive. If you look through the top grill you can see it's a Western Digital 160 gig drive.
Hey good call! Never even thought to peek inside the top grill Glad you're up and running.
post #33 of 401
well, i tried to get myself a 3012, but i am just outside st. louis county, so we wont have them for another 6 months or so says the tech that i spoke with today. (franklin county, mo)
post #34 of 401
Originally Posted by jas09 View Post
I had a new Moxi installed by Charter two days ago and can provide my preliminary review if anyone else is considering it. Installation went fine, but I had a good tech (thanks Steve T!).
1) Interface and behavior is exactly the same as the old Moxi, but noticeably slower. The speed degradation is particularly noticeable when doing a title search (which was always slow, but not this slow) and FF/RWD on recorded titles.
2) Only optical out, which could require running another audio line (did for me).
3) Based on the amount I have recorded (about 4 hours of HD and 1 hr of SD) and what the Moxi is reporting (26% full) it does *not* have a 500GB drive - 160GB sounds right to me.
4) Relatedly, only eSata support so if you were using an external USB drive with your old Moxi (which I was) you're SOL. Ordered an eSata enclosure to put an extra drive I have lying around - I'll update and let you know how that works when I get it set up.
5) Runs significantly cooler and quieter. I was always concerned that my old Moxi would burn my house down, and the heat issue almost certainly caused the premature failures (I went through 3 old Moxis). Also, while the old Moxi could always be heard, the new one is only noticeable if you're up close. I'm hoping it also draws less power (since you can't turn it off) but I haven't been able to confirm this.
Bottom line, if you like the old Moxi, you'll want the new one if only for reliability reasons. Hopefully it will get a firmware update at some point like the old one did that addresses some of the performance issues.
Is there only one optical out? Don't most people run tv and DVD thru their surround sound? and the switch from USB to eSATA on EHD - always thinking of the consumer!
post #35 of 401
I'm not sure I understand your question ... the number of outputs on the Moxi doesn't have anything to do with running surround sound from other devices. My receiver has 4 optical inputs and 2 coaxial ... plenty to go around.
post #36 of 401
Since my channel mapping has been fixed I think I'd have to state that the SD channels on this Moxi are definitely better looking than the older model. Now, I also switched from component to HDMI which shouldn't make a difference really ... except for the fact that I have to turn 480i off to use HDMI so my TV is doing some scaling. However I tried that before on the old Moxi too. Anyhow, I stated early in this thread that I thought the SD looked the same, but I now clearly think they look better. What cemented this for me was Top Chef, which I watch every week on Bravo (come on Charter, we need BravoHD!) and it looked pretty good this week.
post #37 of 401
Originally Posted by black_macleod View Post
As noted in the 1st post, there is anecdotal talk that this is possible. Its on my list of things to try, but it involves moving some gear around the house and I haven't had time yet
Right you are...I missed that.
post #38 of 401
So to get get ready for my 3012 install tomorrow I decided to save some money and crack into my existing External USB drive that I have hooked into the Moxi. I am using a WD My Book 500gb USB2 drive currently. I figured that more than likely the drive inside would be SATA and so that hopefully I could turn the drive into a eSATA with minimal effort. I started by ripping the drive out of the enclosure(yeah its a little beat up now) and discovering that the drive was connected using a SATA+Power all in one cable. I used a dremel tool to cut the 2 cables off so that they both remained usable but could now be plugged in separately. Once the cable issue was solved I then used the dremel tool yet again to cut open a small hole in the enclosure to make way for my eSATA cable. Once the hole was in place I went ahead and plugged in the power cable and the existing SATA to USB cable back in its place so that it could continue to function as a USB drive. Once I am ready to go eSATA I should be able to wiggle the SATA cable free to make way for my eSATA cable without having to dismantle the enclosure yet again.
I think I have 3 possible outcomes with my doing an upgrade this way....
1. Everything will work fine, drive will format and I just saved myself some money...
2. Internal check on the External drive enclosure sees no hard drive is installed and turns off/goes into sleep mode.. Don't think I could work around this one but I doubt it will be an issue.
3. Internal check detects that the USB port is not active and goes into sleep mode/turns off. I think this one could be fixed by just plugging the USB cable into the Moxi just so it detects some sort of connection on the USB cable. I again don't think this will be an issue as the My Book, unlike some other models, have never gone into a sleep mode so I don't think they support doing this on their own.
All in all I hope/think that I will have a fairly cheap and easy eSATA enclosure that will work with the new Moxi. The only part required to get this done is a SATA to eSATA cable that I will 'borrow' from the office. Now I just have to hope my install goes smooth and that I didn't do all this effort for nothing.
I have included a few photos taken with my Iphone..
post #39 of 401
Or you could buy a $25 eSata enclosure from newegg.com
post #40 of 401
Yeah I could have gone that route, but at $25 dollars I probably would have ended up talking my self into just buying a new larger drive as I could have a found a use for the My Book somewhere else on my network without issue... And with a baby on the way I figured I was better off attempting this cheaper route..
post #41 of 401
Hey I'm all for tinkering! Let us know if it works. Congrats on the baby!
post #42 of 401
To those of you have received the new Moxi 3012 from Charter. Are any of you in St. Louis City, or is this box only available in St. Louis County
post #43 of 401
I got the new MOXI, and I'm in neither. Belleville, IL here. The guy that installed mine said he had to pick it up in Fenton, MO.
post #44 of 401
Any success thus far on recording from the 3012 to permanant storage as an avi/mpeg/etc? That'll really be the kicker for me on deciding whether to get external storage or not...
post #45 of 401
Some good deals lately on externals. Here is just one:
http://dealmac.com/Fantom-500-GB-e-S...ng/275569.html
There is the same model at 750GB too
post #46 of 401
Nope, nothing that is going to be easy.
post #47 of 401
Yep its those cheap prices that is why I know I would ended up buying new...
But to report back My install of the New Moxi went fairly well.. Took an extra reboot or two before everything was in order so the tech probably spent a bit over an hour here.. He was a very friendly guy and actually seemed to know a decent amount about Charter's hardware something some installers really lack. So far my eSATA conversion drive is working as expected and formatted without a problem. I'll report back a more comprehensive review later once I have more time to use it after scheduling back all my fracking shows...
post #48 of 401
just got mine this morning. i'm in stl city. from what the installer told me, i might be one the first in the city, if not the first. earlier this week he told me that it wasn't available in the city. hope this helps.
post #49 of 401
I got mine at 8:30 yesterday morning in the city... and the installer told me I was the 4th in the market to get a 3012. Methinks there is some misinformation (probably not intentional) out there. Nice guy though.
post #50 of 401
I was perusing a device such as this:
http://www.amazon.com/dp/B00180MMZC/...0&linkCode=asn
You could just keep a couple of drives around and swap em out as needed.
post #51 of 401
Hi,
does anyone know if these are being installed in Texas yet?
post #52 of 401
Ok, after a few days of use, and adding about 70 series to the schedule I thought I would go ahead and share my thoughts on the new Moxi Cable 3012 DVR.
At first glance I haven't really noticed the interface being much slower, or the search being much slower. I think some of this could be the fact that the first Gen Moxi went through several software updates to speed things up but more than likely the majority of my searches were all done before these software tweaks were put in place.. Meaning most of my reference for searches would have been during the slower time of the first gen moxi. It is still slow, and still a bit clunky to search through but overall I don't think its much worse than the First gen Moxi...
HDMI 480i seems to be working for me. With the first gen Moxi if I used 480i with a DVI to HDMI converter I always had a weird picture issues in the center of the screen. So I always kept the first gen Moxi at 480p and out of Habit I may end up doing the same with this box. I tried to see if I could tell a picture quality difference between 480i and 480p and I don't think I noticed any. As far as picture quality of 480 content looking better than the first gen moxi I would say this newer box may have a slight edge. But without seeing the two side by side I would say its just a slight edge and not any kind of night and day difference.
The actual handling of the videos and play back though does seem to have taken a step backwards. When I delete a show it remains playing in the background for a longer period than the first gen box did. This doesn't really cause an issue I just find it odd that it takes so long for the stop and delete process to complete. Also, and most annoyingly, the 30second skip now sucks hardcore(well I guess no 30second skip option would suck more). The video now seems to pause, think about what its going to do, then skips ahead 30 seconds and starts playing back. The first gen box would respond just about instantly, move you to the new spot in the video and let you see what spot its stopping at, and then would resume playback. This allowed you to quickly see where 30 seconds take you allowing you to almost instantly hit the 30 second skip again if needed. This bug would be top on my complaint list and I hope its something that they fix in the first round of updates for this system.
On the list of things I do like though that would include the support of eSATA drives. I think/hope that with the overhead of USB gone it may give Digeo the ability to make things perform a little better or more consistently for users. Also, when your watching, or have selected recorded content it now includes more options for editing the series and such so it is nice to now have more things at your finger tips without digging through the Moxi menu. The Moxi is now cool to to the touch all over the place. I think this is a good sign that this system will be much more stable and should last as long as the hard drive in the system is capable of lasting. The open top vent should do a good job keeping things running but I do wonder what kind of issue dust will have falling directly inside the case. The good part is it should be easy to use the Air in a can to keep things clean now that you can clearly see all the components inside. The only downside to this reduced temperature on the box is my cat will now have to find a new place to sleep, but I won't miss the times where her tail has blocked the remotes IR Port.
Overall I like the new Moxi and with a software update or two hopefully it will eventually start to surpass the experience of the first gen system. I'm not quite sure why they would have taken these steps backwards, but for all we know Charter is a software version or two behind what Digeo has released since we all know how slow Charter can be to approve different revisions. The 30 second skip is my only real complaint, but it definitely something I can learn to live with if I must. If you have a first gen Moxi then I don't see a reason to be in a hurry to upgrade but at the same time I have no regrets in upgrading mine.
Its too bad we lost our direct line of communication with Digeo since it seems they no longer monitor/post in any of the Moxi topics. I think it helped a lot of users through the first gen growing pains when we knew our complaints were being heard and addressed by Digeo development. I suppose I will find a contact option on their web page to complain to them about the 30second skip stupidity.
-Phatty
post #53 of 401
My 30 sec skip works the same as my old Moxi, I don't notice any of the behavior your are describing. Weird.
The 480i/HDMI issue may be my TV ... I'll try another port and/or dig up my manual, hehe.
post #54 of 401
Well sucks to hear that unless somehow our boxes are running different firmwares. The 30 second skip is my only real complaint as it just feels clunky now compared to how it was before....I also doubt that we are running different software versions but I can hope as I doubt its worth a box swap for something so minor(yet annoying). I will manually initiate a software update and give it a fresh reboot before recordings start tonight and see if that clears anything up.
post #55 of 401
Phatty I agree with your review of the new Moxi box and think your right on target with your review and feedback.
I have noticed that although the box is slightly slower overall operations of the interface is more consistant. Meaning not as many LONG pauses.
I can confirm the 30 sec skip feature works as you describe (poorly) and yes video playback controls overall feel clunkly.
It is unfortunate that the likes of MoxiGuy are no longer around to fill us in and provide feedback due to employee cuts at Diego. If you think about the last couple years with the Moxi being out of production poeple have been fighting to keep their Moxi boxes over the years. I think that really made the orginal Moxi box into the box it is today. More companies should learn from this example because I believe it made for a very loyal fan base.
post #56 of 401
Well lets do a software version check
Mine is: 4.1c.0.109C3R-P.231969
(That's from Settings / Storage & Stats Menu)
I think I'll quantify my previous statement too. I will admit the skip feels "different" than my old Moxi, but I wouldn't say its slower. I can still zip through the commercials pretty fast. In our discussions of the new Moxi interface, I would describe the entire thing as more "spongy" -- if that makes any sense to anyone!
post #57 of 401
I was hopeful an update was ready for me as the App, Boot, and Updates version all showed the same 4.1c.0.109C3R-S.231969 and the software version was the same P as yours.... But in the end even after initiating an update manually I have remained on the same software version as you.
Also the 30 second skip probably isn't as slow as I make it out to be. I think the difference is I believe the first gen box would immediately take you 30 seconds ahead where you would see a paused image of the new scene that would then start playing.... Now it seems to skip ahead 30 seconds in the background, then starts playing immediately.. Meaning you have to wait around for the new video scene to start playing again before you know if you should hit the 30 second skip one more time. It probably only amounts to an extra half second or second it just feels more clunky to me.
post #58 of 401
Well I'll have to say I can live with all this given how quiet this box is. I love it.
post #59 of 401
*Edit* Oops, I just found I won't be posting in here because, according to my tech, the 3012's aren't gonna make their way out here. Charter is supposedly cancelling the account with Digeo. Not so sure I believe him though.
post #60 of 401
Hmm. Well the Moxi's do cost Charter more ... given Charter's ill health and the ill economy ... who knows. They can rip mine from my dead hands!
  Back to Forum: HDTV Recorders
