I haven't done build threads before because I suck at it. I've also known that subwoofer manufacturers have read most of what we discuss in these forums over the years (several have told me, and it's only common sense) so I chose to keep some things less obvious.
With this thread, I've decided to have some fun, but it will be as time permits and I apologize in advance for being lame at this sort of thing.
1) Over the years I've had numerous requests to explain ThruVent Cooling. I will explain it in detail in this thread and answer any questions.
2) I thought it might be interesting to compare the Tumult MKI against the Tumult MKII when both are in the same environment with the same signal and in the same enclosure. This is a week or so out, but I'll post some results for discussion.
3) I recently finished 3 subs and I'm waiting for the glass tops, so I'll hold off talking about Driver-Vu until they're installed, at which time I'll post pics and details.
In the meanwhile...meet The Raven...
Tumult MKI vs Tumult MKII
ThruVent Cooling System (diagrams and full details coming)
Driver-Vu (design, materials and details of the advantages coming)
Bosso
Bosso
Stunning!....Well thought out implementation as always Bosso. One question.....how many DB's are you gaining from the lack of thermal compression from heavy use? Do u notice a big difference or is it mostly to protect the drivers? I don't think I've ever seen this on any commercial setup I 've seen.
