AVS › AVS Forum › HDTV › HDTV Technical › Is this possible
Is this possible
post #1 of 3
Here is the scenario:
Three rooms, three tv's, one ancient plasma which is about 8yrs old, no DVI, two newer LCD's. We have a mix of OTA sat with two tv's having boxes, and local cable feeding directly into one TV.
What we want to do if possible, is make it so that any tv can have access to OTA or local cable, providing there is some way to easily switch, via remote, between either OTA feed or local cable.
Any ideas?
post #2 of 3
Do your TV's have separate antenna and cable inputs>
post #3 of 3
Is that OTA satellite or Local OTA channels?
What are the two boxes?
  Back to Forum: HDTV Technical
