Hello All,
I have been trying to better understand the benefits and negative aspects of tower and bookshelf speakers. I have read several of the existing threads but still have questions.
I understand that tower speakers have larger cabinets and can have in many cases a 3 way design as opposed to the more standard 2 way design of most bookshelf's. In three way designs with correct crossovers it allows each of the components to function at its best frequency range. But isn't this also accomplished by a 2 way bookshelf and subwoofer? Looking at some bookshelf specs from different companies it seems that average range is somewhere in the range of 50 hz to 20 khz and 30 - 180 hz for the subwoofer resulting in a 30hz to 20 khz for the two. The towers I reviewed are in the 30 hz - 20khz range effectively covering the same range. Is the subwoofer location identification the issue here?
What would some of the other pro/cons be if driven by a sufficiently powerful receiver and both are using the same quality components. I know that the bookshelf's would need to be on stands as well.
Part of the reason I am looking into this is that I have a basement that I am turning into a media room (If I ever get done) and have been thinking about some of the audio options. The room is approx 15 w X 22 l X 7 h and will be used primarily for HT but also some music ranging from rock to jazz/blues to classical. Space really isn't a constraint.
Thanks in advance for any guidance or information you can share. This way I can be better prepared as I go and review different setups.
) and have it all properly balanced and EQ'd.
