Originally Posted by Orta
I'm not sure if this is what you meant, but the CRT test was actually done by a different user with the 650. My post was indeed poorly worded and suggested it was One's tests, but I was just giving him credit for finding it. It is interesting the 630 differs. I would be more apt to side with it being firmware bug.
Assuming that a fairly standard and typical LCD monitor (Gman's control) has 0ms lag would be a worse idea IMO.
True and that is why I made sure I documented the control. But also keep in mind that, even with CRT's input lag advantage, a great majority of consumers are going to chose between LCD monitors or HDTV's (Plasma, LCD, DLP, etc) for gaming (or soon anything).
Also, the results when testing the 650 to a crt are likely going to be in frame increments, correct? So anything at a non-native resolution for the 650 is likely going to cause at least a frames delay (16ms)? At best it is going to show 0 some times and ~16ms others? That is of course assuming the CRT has absolute 0 input lag.
The only way to accurately measure the true difference in input lag would be using an oscilloscope. The picture method we used here is only moderately accurate (at best) when talking about 100ths of a millisecond. There are timing factors that cause the variance due to the timing of the frames themselves. I believe this is the primary reason for the variance and range we see during this test method.
The most important part of this thread (in my mind) is documenting the differences for the 650 and its various modes/inputs so it can be setup to best suit the owners needs. For that, the control is really irrelevant.
