AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Can I use 16:9 and 2.35:1 screen with Panny AE3000 lens zoom?
post #1 of 4
I have a motorized drop-down 123 inch 16:9 screen. I was thinking of getting the Panny AE3000 and mounting a fixed 2.35 screen on the wall directly behind the 16:9 screen. This would allow me to have best of both worlds by filling both screens without any overshoot. Will this work? Thanks.
post #2 of 4
Yes as the lens for 2.35:1 mode is able to be memorized. BUT, you would have to refocus since there is no way to not have some distance between screens. I am not 100% sure, but I do NOT believe you can save focus in memory (just zoom).
post #3 of 4
Just confirm that focus is saved in the lens memory. It's best to save the three memories once the PJ has warmed up as I find mine drifts a little from cold, but if I use one of the presets then, once it's warmed up, the focus is very consistant.
I'm not in the habit of contradicting Jason, but on this occasion, I think I'm on safe ground as an AE3000 owner myself.
post #4 of 4
Well then he is good to go!
